epsilonGreedy Posted September 28, 2020 Share Posted September 28, 2020 My carpenter failed to show at the weekend to prep the wall plate timber for the brickie to bed down. To help get things moving I plan to cut the timber lengths to match the dimensions of the inner block wall (plus 100mm for each half lap). Now I am considering the finer points of the job. I understand the preferred minimum run of a timber section should be 3m or failing that a section should support a minimum of three truss ends. (My wall plate was delivered in 4.8m lengths.) What about an abutment where the wallplate meets a chimney or a single story wallplate butts up to a two story wall. Should I allow for a 5mm expansion gap? In the case of outside hip corners, is a standard half lap joint still recommended? I ask because I saw a video where a 45 degree chunk was lopped off the corner of the wall plate to accommodate the fall of the hip timber. Link to comment Share on other sites More sharing options...
