September 1, 20206 yr Hi guys - I am looking for a CAD technician, with full knowldge of the Building Regulations, to convert my layout sketch to a set of Building COntrol and Build drawings - any recommendations? I am not looking for the full architectural service, but person must be able to take the lead in the area of compliance/regulation. TIA, James Edited September 1, 20206 yr by Jimbo37
September 1, 20206 yr They're called Architectural Technicians if that helps you find one. (Or were you after a name individual? I wouldn't have thought that necessary as the service you require is mainstream and so there should be plenty local to you which can be helpful if there are any nuances with how your particular BC operates)
September 1, 20206 yr Author 1 hour ago, MJNewton said: They're called Architectural Technicians if that helps you find one. (Or were you after a name individual? I wouldn't have thought that necessary as the service you require is mainstream and so there should be plenty local to you which can be helpful if there are any nuances with how your particular BC operates) Thanks, I’ll repost
