Steve_cock_on Posted August 24, 2020 Share Posted August 24, 2020 Hi all, I am about to cut a single brick wall opening, in a garage to take a side door/frame. I am trying to find what clearance over the frame width to make the opening. The frame is very parallel +- 0.5 mm, my thoughts are maybe 5 mm each side 10 mm total. Any experienced thoughts welcomed. Thanks. Link to comment Share on other sites More sharing options...
markc Posted August 24, 2020 Share Posted August 24, 2020 Quite difficult to cut an opening within 5mm ...., you end up faffing around and trial fits many times. I would go for 10mm all round as this also gives a descent gap for sealing. Link to comment Share on other sites More sharing options...
