David Beecroft Posted July 8, 2020 Share Posted July 8, 2020 Hi everyone, Simple question, how do I install a upvc window unit into a steel frame? What fixings do I need to use? Any polite advice appreciated. Thanks, David Link to comment Share on other sites More sharing options...
PeterW Posted July 8, 2020 Share Posted July 8, 2020 TEK screws and the correct window straps ..?? Is the steel frame inside or outside the envelope of the building ..? Link to comment Share on other sites More sharing options...
David Beecroft Posted July 8, 2020 Author Share Posted July 8, 2020 Thank you for responding. The porch is an addition to the exterior of the building and has an external grade door between it and the interior hallway, so I guess the I would consider it to be outside the building envelope. Would I expect the correct window straps to be supplied by the window fabricator? Link to comment Share on other sites More sharing options...
