Dan_the_man Posted June 18, 2020 Author Posted June 18, 2020 46 minutes ago, PeterW said: OK so the internal (front to back) depth of standard cabinets is usually about 560mm anyway, and it depends on the configuration of the internal frame for a larder and that can remove between 40 and 60mm so you cannot get more than 500mm normally. With this in mind and my desire to get the bigger depth I have to go with the blum pull out drawers. Would they be best suited directly opposite the island? I would pull them out and only be able to access them from one side, but at least this way they could be left open and unobstructed access to the fridge is granted. As they are on the images I have attached they would have to be closed each time I need to access the fridge.
