Homer92 Posted March 9, 2020 Posted March 9, 2020 Quick query - I will have 100mm PIR board between sloping rafters and 50mm below, then in the voids 200mm rockwool between joists and 200mm above. Do I insulate between the vertical timbers? With the same as rafters 100mm and 50mm PIR, or does it not require insulation at all? Thanks
A_L Posted March 9, 2020 Posted March 9, 2020 18 minutes ago, Homer92 said: Do I insulate between the vertical timbers? If there is a path from a heated area through the vertical timbers to the cold outside without passing through insulation then yes, otherwise no
