Planning the opening size for the above and wondered if you insulate these ducts through the opening up to the outer skin of the house or just to the inner skin. So if I have 150mm duct is the hole 150-160mm or more like  ~180mm to allow for some insulation? Build is ICF if that makes a difference.
In case of help to anyone in future  - recommendation from supplier is insulate from the mvhr unit to the internal wall face so a 150mm duct would need ~160mm hole
