8 hours ago, ProDave said:
It is generally recognised that using burst firing of an immersion heater, you need to keep the flow of energy back and forth to under 1Wh so it does not get metered.  I suspect just counting 1Wh pulses would be too coarse for that to work.
Yes it would be, as the meter anti-creep threshold is usually about 1 Wh, so if you want to bounce energy back and forth when running water heating from excess PV generation then you need to meter to a fair bit finer resolution than 1 Wh.
