About Post and beam
- Birthday 09/30/1959
Personal Information
Location
North Hertfordshire
Post and beam's Achievements
Advanced Member (5/5)
197
chatGPT and the like for landscape inspiration
Post and beam replied to Post and beam's topic in Boffin's Corner
I would not rely on any AI generated content. But i will view all designs and pictures it creates to see what i can take from it. If it sparks either my wifes or my imagination with any good ideas for layout then it will be worthwhile. -
Not yet but chat GPT says it can do this. It even claims it can prepare building control spec drawings. I am also planning to spend sometime out in the sunshine today as well, staking out options for paths, drive way etc. I need to try to stake out the relative heights. also need to accommodate the Wife's flower beds. I am not very imaginative in this regard which is why i wondered what AI can do. -
On the graphic that displays my 'obstructions' there is a quite large area behind the antenna that shows as a problem. This is because it is mounted on my chimney at about 12' up and the house is the obstruction it sees. This is with the antenna pointing north west which is apparently where the satellites come up over the horizon from. I would imagine my signal is handed off to the next one in line before the slightly behind obstruction becomes an issue. I do have a hazel tree partially in the way to the low left of my line of sight but it does not show up as an issue on the graphic. In practice none of the above is a problem 99% of the time. I think other factors are what cause the very occasional buffering in the evenings.
Like a great deal of what the state provides in this country these days. Lots of encouraging words and 'plans' But very little apparent provision. Yes i know that Openreach are a private commercial company but the vision is the governments and they are not great at delivery.
To date my experience of Starlink has been excellent. The product and everything in the box is top quality and well presented. It works very well and is dead easy to set up.
https://starlink.com/public-files/accessories_guide_standard.pdf I bought this, its the standard wall mount. Solid as a rock
It’s coming out the hole
Post and beam replied to Pocster's topic in General Self Build & DIY Discussion
Plenty of engineering text books with tables of figures for every type size and material of fixings. Google is your friend. -
Aerobarrier air tightness product/process
Post and beam replied to thaldine's topic in Heat Insulation
Discussed this before elsewhere on the forum. I paid £2100 for a 200 sq metre house last autumn. Result went from 3.8 to 1.4 over a few hours. The guys did have a couple of leaky nozzles on their kit which left an invisible gloop on my walls. It is a bitch to remove, as i found out once i discovered what had happened. -
I was shown today how AI can generate ideas for lanscaping when given a photo as a base reference. Question, has anyone done the same successfully from plans and elevation drawings.
ASHP BUS Grant - when does it pay out?
Post and beam replied to Great_scot_selfbuild's topic in Air Source Heat Pumps (ASHP)
The installation company i chose and subsequently turned out to regret Left me with a few questions once they left site for the final time. On this basis i was very reluctant to pay them the final invoice which basically covered the grant. They very quickly started to hassle me to pay. Stuck to my guns and argued that once they had all their money where was the incentive to #1 sort the issues & #2 actually get the grant money to me. As it turned out i spoke to the MCS people myself. They were very helpful and told me that the company had not responded to them within some time limit which killed the grant claim. The installers own incompetence had cause their issues. If you knew the full sorry story of this shower this would not come as any surprise to you. Anyway, MCS said that it was perfectly possible for the installers to resubmit the claim which they duly did once i informed them that their failings were at the root of the delay. MCS paid out within a week to their credit. Still waiting since 9th December for a resolution to our losing pressure issue from this bunch of chancers. -
I wonder what hardware and service level this is. My antenna cost £275 in November and i pay £75 month. sometimes get up to 300Meg download.
The Starlink cable is proprietry and a standard ethernet cable will not work. The ends of the Starlink are slightly different. They also claim that because their antenna is quite high power that ethernet cable cannot cope.
Before i ask the Planning department the probably painful question of what their requirement is with regard to our Bin location, does anyone have any insight please? Our 'pre first occupation' condition #13 requires us to submit full details of how and where we will locate our bins & recycling containers. We have already moved in by the way. My response would be, ' over there mate out of the way'. I doubt this is what they want. For those that have been here, what level of detail are they likely to be expecting?
Why did you choose an air source heat pump?
Post and beam replied to SimonD's topic in Air Source Heat Pumps (ASHP)
New build well insulated, UFH and air tight ( ish). Mains gas is not available on our plot and the delivery was going to be £6500. Not usually factored in when people discuss how expensive heat pumps are. Finding a heat pump installer was difficult and to be honest the company i chose have ended up being a total incompetent nightmare. Hey ho! lesson learned.
