binary
Everything posted by binary
  1. Just a note on the heat pump information i included: the cost of the heat pump can be reduce if you are willing to locate a different delivery option the cost is also in US dollar so your pound will go further, as for Monobloc version you won't need a engineer to install under Part F gas as this type of unit is an enclosed unit different to a split version which needs gas charging
  2. Hi This may help, if you install yourself you may be best with a monobloc version air to water heating and cooling .pdf
  3. In the planning stage of new build currently applied for Certificate of Lawfulness very old electrical Qualifications and retired
