Gadget Buster
Everything posted by Gadget Buster
  1. Thanks for that, are you saying that you installed your corner profiles after you fitted the click boards?
  2. Hi thanks for your help so far. I have drawn a scale drawing of what i think my installation might look like. do you think this would work? are the cedral click boards made of something that i can router? are they made from a carcinogenic material at all? Please see the attached picture and ask any questions you like. So the part in question is the cedral board that i have coloured yellow, i am thinking that if i set the batten slightly back from the face nearest the french door (by about 6mm) then that will give me enough room to have a reveal, that would mean though that i would need to router the back of the cedral lap slightly so it fits in the gap. Do you think this would be possible. I dont think i would be able to instal the corner profile before i put the reveal board in but i could use color coded nails to fix the reveal and corner profile on that side and then fix it normally on the front. Thanks again
  3. Thanks for your reply, i was more concerned with the mechanical fixing of your reveal. The standard way the reveal is constructed on their installation document just would not work for me as i can't batten the reveal as it is on about 10mm deep. Did you use a bought profile from Marley to finish off you window edges or did you buy from a different supplier an L shaped profiles to finish off the corners. thanks for your help
  4. Hi, very interesting post. I am looking to instal cedral click but like you have a very limited reveal. Can you explain how you dealt with yours as you look to have a similar very small reveal. I am finding none of the off the shelf trims will work for me. Hope you can help. Simon
