Gadget Buster
Gadget Buster's Achievements
New Member
New Member (2/5)
0
  1. Thanks for that, are you saying that you installed your corner profiles after you fitted the click boards?
  2. Hi thanks for your help so far. I have drawn a scale drawing of what i think my installation might look like. do you think this would work? are the cedral click boards made of something that i can router? are they made from a carcinogenic material at all? Please see the attached picture and ask any questions you like. So the part in question is the cedral board that i have coloured yellow, i am thinking that if i set the batten slightly back from the face nearest the french door (by about 6mm) then that will give me enough room to have a reveal, that would mean though that i would need to router the back of the cedral lap slightly so it fits in the gap. Do you think this would be possible. I dont think i would be able to instal the corner profile before i put the reveal board in but i could use color coded nails to fix the reveal and corner profile on that side and then fix it normally on the front. Thanks again
  3. Thanks for your reply, i was more concerned with the mechanical fixing of your reveal. The standard way the reveal is constructed on their installation document just would not work for me as i can't batten the reveal as it is on about 10mm deep. Did you use a bought profile from Marley to finish off you window edges or did you buy from a different supplier an L shaped profiles to finish off the corners. thanks for your help
  4. Hi, very interesting post. I am looking to instal cedral click but like you have a very limited reveal. Can you explain how you dealt with yours as you look to have a similar very small reveal. I am finding none of the off the shelf trims will work for me. Hope you can help. Simon
