AnnaKH
AnnaKH's Achievements
Member (3/5)
3
Thanks for your feedback. Here's the spec of the tap - https://cdn.shopify.com/s/files/1/0222/7290/1216/files/Ellsi-PDT-000014-datasheet.pdf?v=1672825838 Height (mm) 295 Width (mm) 210 Length / Depth (mm) 45 Inlet Connection: 1/2” BSP Flexible Tails Tap Hole Diameter: 35mm I was looking at stainless steel deck plates to mount the tap onto on the surface of the worktop - might that help?
No - I bought a narrow edge stainless steel drop-in sink. I'm willing to admit that in my decision-fatigue, I went with what I liked the look of instead of what might be most practical!
The worktops are Spectra Square Edge laminate - BS/EN438 laminate surface bonded to EN312/2003 E1 high density particle board.
Hi, I'm looking for advice on how best to mount a monobloc tap on a 22mm laminate worktop. I had hoped to get a thicker worktop but due to stock and needing to complete asap, I've opted for the thinner one. Are there brackets? mounting plates? something that will help secure the tap and cause as little damage to the worktop as possible? Thanks for any advice!
Three years living in Llantwit Major and this is about the extent of my Welsh!
Thanks @Nickfromwales, that’s great. Diolch!
Thanks for this advice, it’s really helpful. We will have a plumber fitting it. My main concern is that I don’t want to create extra work and cost just to go with this new bath I’ve decided I like - is the work you’re describing quite straightforward for a professional? Thanks
Ok, please excuse my terrible sketch and zero understanding of plumbing! The screed floor is already laid so it would need to be an exposed pipe underneath the bath running to the waste pipe in the corner. Would that work? I don't mind the pipe being exposed. My concern is whether there’s enough clearance for the pipe to be at the required gradient - the space under the bath is 147mm and the ‘drain pipe’ in the corner is about 930mm from the bath hole (I measured it out). The tiles for the floor are about 15mm. For the taps, I'd quite like a boxed-in area (see very bad sketch) which the taps could sit on (that way I get a ledge as well). Could the hot and cold pipes run horizontally into the boxed in area, then connect to the taps? Total width of the wall is 1800mm, so once it’s tiled, there will be a gap of about 40mm on either side. I take the previous point about squashing in a nice bath to a small space, but I’m happy with that look. Thanks for any advice!
Thanks @Temp, that sounds similar to what I’m planning. Do you know how much clearance from the floor to the underside of the bath you had, and how far away the drain hole (?) was? I think this is my main worry as there’s a specific gradient for building control.
Thanks @Nickfromwales, I’ve sent you a message with some details and questions!
Hi, I'm looking for advice on whether I can fit a freestanding bath in our new house. The first fix plumbing has already been done, and I don't want to undo anything, so if the freestanding bath isn't possible, I'll go for a built in bath. If anyone can advise, please let me know and I'll message you some images. Thanks
Hi, I’m looking for advice on what type of render to go for. We’re building a timber frame house with block and render. The house is in a coastal, exposed site very near a sea loch and a few miles from the sea. I had thought that a silicone render would be best, however I’ve heard bad things about mould and the porosity of it. Can anyone advise what type of render will be most effective in withstanding the elements? Thanks
Hi, I'm looking for information on putting in a polished concrete or microcement floor in our build. Does anyone have any suggestions of trades in Scotland who specialise in installing polished concrete or microcement floors? Thanks, Anna
Hi, I'm looking for advice on PCCs for a self-build loan. We require PCCs for loan stages to be released, however we also want to get a structural warranty. As we're in Scotland, the building control will be done by the council, so we might end up having three sets of inspections - one for building control, one for the loan stages, and one for the structural warranty. Is there a way of combining any of these? Or are there structural warranty providers who can use the certification from the loan and building control rather than sending out their own people? We've had a quote from Protek, but the majority of the cost is sending someone out to do the inspections, and the inspections won't match all the stages of our loan so we'll have to pay extra for desktop certificates for these stages. Any advice would be welcome! Thanks
