Diy
Everything posted by Diy
Yeh fair enough a fair few coats and also some is hard distemper and other is soft
Will be doing it bymyself any reply would be much appreciated
How long would it take to sugarbsoap off distemper from all walls and ceiling in a 10x14 room
How long in hours would u say please as teyimg to argue with landlord about how long the job will take much appreciated thanks for getting back so quick
Yeh 7.5 and the ceiling is blowing in the middle really bad
The property is 1950s
No 7.5mm it is really thin so look like something else that need to be replaced in the house
Is 7.5kmm plasterboard to thin for a ceiling
Have u any info on roof and pictures
Did you get last message
Thank we wanted to store stuff up there if you see all my other problems with property then you may understand state of property we have distemper on all walls and plaster falling off and massive cracks so not sure it safe
37mm width and height 70mm and 9cm plaster board sorry productive text also a big sag in middle of ceiling
Just wanting some advice ceiling bowing g in middle buy at least an inch and lost only has 9m plaster board and 37mil joists is this somethink to be concerned about
37 mil buy 70 fathers in attick as well so very small
So what is in the picture then as can see wood
Going to check the attick out today and see what is happening
Going to have a look in attick today to see what is causing issue
Unless its lath as not looked under insulation
Distemper on the hole house have zonnzergards and still paint is coming off and plaster bubbling and skimming falling off
