Patrick williamson
Everything posted by Patrick williamson
  1. Had southwest water check outside drains all found to be ok. Had these CCTV as well
  2. Hi drain is used by 2 other properties
  3. Hi the boxing I will get my plumber to look at this .this week Neighbours don't have any basements,
  4. Sorry I am a novice . 4th photo joint not sure your meaning
  5. More photos had gutters cleaned . Told that can overflow drains in courtyard up to 6 inches before it slowly drains away.bso thin Nking it finds it's way between walls .
  6. Hi not really as this problem happened while away so had a friend take photos will add some more but . Not sure if will help
  7. Told that can overflow drains in courtyard up to 6 inches before it slowly drains away.bso thin Nking it finds it's way between walls .
  8. Sorry not at moment . Due to lockdown I am unable to visit . It's a holiday home so 400 miles away. I wanted to see if this a job for a builder or plumber or specialist. Or see if can redirect rainwater from roof to another drain.
  9. Drains go under the house so cannot dig up or put frenchvdrains . In.
  10. Hi built around 80 years . Shared drains . Seems has been tanked. Drains not up to job so can not get rid of excess water. So any overflow gets in basement
  11. Hi no this is not possible due to where the pipes are see some photos
  12. Hi I have a leak that is coming into my basement , only happens during heavy rain. Had drains checked by water company and these told are fine . They put dye into drains and nothing showed up.When drains cannot cope water over flows so I am thinking it's getting in via concrete or fissure. Any advise best way to seal from happening . Basement ceiling and walls get damp and discoulrs paint . Area is a small courtyard out back and standing water eventually drains away Any products to seal or specialist companies around to get this sorted, Thanks
