Hi,
	building a garden studio with SIP panels. Floor and walls 100mm, roof 150mm.
	Size is 4x3m
	The base is a full concrete slab same size 4x3m. 150mm subbase + 100mm concrete (not insulated)
	Can I:
	a) lay the SIP floor on the concrete with a DPM membrane in between? Membrane will be wrapped up the wall 1 foot height.
	or
	b) do i have to ventilate between the concrete base and the SIP floor? Also using a membrane to wrap the base.
	I'm trying to minimize height, so i'd rather go with option a) if possible, but not sure re the ventilation.
	If i have to go with option b), what size gap? and can i use lines of bricks rather than wooden rafters to avoid wood degrading over time?
	Not an expert, so thanks for any help.
	Paul
