Hi,
Can anyone advise on the dry hip and dry ridge installation on a new build property I am about to purchase.
I have some experience of roofing and dry ridge but not this type.
The dry ridge has 3 clips at each ridge tile joint. most of the clips are not fully home and raised above the ridge tiles. See Photo
The dry hip looks a mess, particularly at the top. See photo. The support for the tiles is buckling causing the ridge tiles to be not seated straight.
My questions are,
. Why are the clips not fully inserted or what is stopping them being inserted?
. Why is the dry hip such a mess. Is it because they used the wrong tile supports. I appears they should be longer and stronger so they lay straight?
. Should the waterproofing roll under the plastic tile supports be molded better over the tiles.?
. Does anyone recognize the hip tiles and if so what make and type, and what is the dry hip make and type?
Thanks in advance
