siva509
Everything posted by siva509
  1. All, I am planning for rear extension in my garden (3m PD), Mine is 1925 built semi in South Birmingham area. I can see a drain in my drainage search(looks like surface water drain, i can see the Mains water and Foul water drain diagrams in the front of the property as per diagram). Also I can see single storey extensions built by neighbours, one of the property is council owned (3M extensions). Severn Trent has two options (1.self certify build over if pipe dia is less than 150mm, 2. Formal application with CCTV drain survey before and after for certification). Any body has idea of the pipe diameter for surface water? Also can I go for self certify option, since i can see the neighbours have built extensions?
  2. where do you buy your materials from. is it mainly online or from in-store? I am also looking for an extension, but not decided whether to go for self managed- labour only or material included.
