MarkH
MarkH last won the day on June 10 2016
MarkH had the most liked content!
Personal Information
Location
Pembrokeshire
MarkH's Achievements
Regular Member (4/5)
33
Ah, my mistake - I was searching this topic only! Thanks!
That is a Willis heater. Can't find anything on here using search, will have a look on the general www.
Decking without footings - bad idea?
MarkH replied to MarkH's topic in Landscaping, Decking & Patios
My nieces were round recently and whilst they were here we climbed the big oak tree behind the house and then later set up a slackline before finishing the evening firing my parsnip cannon into the woods... Safety glasses were worn for the parsnip cannon. All points accepted regarding railings! -
Update on this - I built the frame and deck without footings, posts resting on on slabs on clay with weed-fabric and aggregate. All seems good - no movement at all. I think it was important that the ground is clay and rock and therefore less prone to move. No balustrade. The drop is over a meter at the highest point but a safety rail would really ruin the view when sat inside on the sofa. I've taken the view that anyone who wanders off the edge should have been looking where they were going. -
Hello everyone, I was thinking - during the coldest months when my house temperature is sometimes a touch colder than ideal - of using the excess solar I often have to run an inline water heater, something like this: 1kW inline water heater I can set up my Victron system to run that heater when the batteries are at 95% SOC or above (which is quite often). Currently the UFH isn't used much - maybe 20 days out of the year. It runs through my combi boiler and works really well just utilising a room thermostat to activate it early in the morning if the house temp drops below 18 degrees. Any thoughts on issues with me doing this?
Completely worthwhile as a toy! I think the best use of a turbine is just steadily contributing energy to a hot water tank - no batteries needed, simple set-up, cheap... Ideal. But only if it's quiet, low maintenance and looks after itself in a gale.
- 34 replies
- electricity
- off-grid
(and 2 more)
Partly due to it's size (not so big) and partly due to the unclean airflow from anything except the South my turbine was pretty loud. The house is massively insulated and triple glazed but the turbine noise was quite un-enjoyable during any significant wind. I'm glad it's gone.
- 34 replies
- electricity
- off-grid
(and 2 more)
Thanks all. I might dig shallow holes and concrete them in that case. But just to be clear - the ground was scraped down into the clay level some time ago and the area I'm decking is not topsoil, that would be daft. It's clay and rock, lots of rock. It's a massive pain in the arse to dig in. It would not be a day's work. Ballustrade, structural engineer - I don't want a ballustrade as it'll get in the way of the view and without that there are no difficult structural considerations. -
But why? -
Absolutely. But it would still have been a noisy pain in the arse! It was an LE-600 with a nominal 750W max output. I'd have a turbine in the future, but I'd want it to be much further away from the house (100m at least) to cut the noise down.
- 34 replies
- electricity
- off-grid
(and 2 more)
The planning permission element isn't a consideration at the moment, just the practical things. -
Just to re-update this - a few more years down the line! I went with Pylontech US3000 Lithium units, initially 3 of them and then added 2 more. They are absolutely great - zero maintenance, zero hassle. With a 6kw PV bank I'm sorted for the vast majority of the year with a generator being required for a top-up 6 times this winter. I expect that when I get round to moving the PV array to the roof and doubling it's size I won't need the gen at all. I'd have no need for the generator if I hadn't ditched my wind-turbine but I don't miss that howling beast when it's windy (there was no easy way of making it play with lithium/Victron). My time with flooded lead acid batteries was educational but I do not miss it! Less of my clothing has small acid burns and the monthly maintenance schedule has become an occasional glance at the Victron App.
- 34 replies
- 5
- electricity
- off-grid
(and 2 more)
I'm planning a large (14.5m by 3m, elevated by a maximum of 800mm) decking outside the back of my house. The ground is solid, rocky clay - not fun to dig in at all. My thought was to cover the area with a weed-membrane and a few inches of aggregate, compact the aggregate and then rest the posts on paving slabs, on the agg. The house is solid wall + 250mm EWI so the decking won't be attached to the house. Is this madness? I really don't want to dig holes!
Just to update this - a few years down the line. My 345ah@48V flooded lead acid bank has done the job for over 5 years now but a very busy recent work period and various other factors have contributed to some shoddy maintenance and FLA doesn't like that. They need tending and every bit of neglect takes it's toll. Anyway - the bank of twelve 115ah FLAs is now a bank of eight battered, prematurely aged sulphated hulks. I'm probably going with lithium - Pylontech. The price has come down, the warranties are long, they play well with Victron kit and will do what they're supposed to without me having to mess around with sulphuric acid once a month.
- 34 replies
- 3
- electricity
- off-grid
(and 2 more)
Velfac (surprisingly, considering Velfac) provide a really very good guide to installing their windows. But when it comes to their external 'Ribo' door there is nothing. The usually helpful YouTube has a stack of videos on how to change the handle but none in door installation. It might be that this is just a basic building technique. If anyone could give me a quick walk through I'd be very grateful. I've got the frame in place and some long screws with plugs to go into the wall. I intended to remove the hinges and strike plates and drill through the frame there, so that the screw heads were hidden. Drill, wall plugs, frame back, screw, door on... Is that about right?
