MAXWELL
MAXWELL's Achievements
New Member
New Member (2/5)
0
  1. Wont be leaving it exposed
  2. Are most brands of the plain P5 chipboard flooring the same quality or are some better than others also are the flooring sheets with the protective coatings worth the extra money as they cost considerably more per sheet
  3. Its on a suspended timber floor, im replacing outer brickwork on bungalow and fitting telescopic vents as the original just had an air brick and no cavity liner, cant see any need for them on concrete floor with ducts leading to suspended floor for ventilation.
  4. Its for the floor on an extension
  5. Is it a must to fit cavity trays over air bricks and telescopic vents
  6. What is the minimum thickness / amount of hardcore you should have as sub base for a concrete floor
