DannyEvs
Everything posted by DannyEvs
  1. Hi @Arvyd Id be interested in seeing this PPT if you can reissue it? The AI worked for me at first but then struggled and now I have switched to a time schedule based on thermostat. But I prefer the concept of AI
  2. @Hogboon Ive got an LG heat pump as well, same controller. I was using the AI function which I believe uses weather compensation to optimise flow temperature, leaving it on 24 hours a day. Seemed to work at first but then temperatures in the house began to fluctuate and now I have it timed via a thermostat. Regarding the controller - if you want to access the settings, you need to go to the settings icon, hold down the up arrow, then type in the software version (4 digits - should be visible on the controller). This takes you into the settings and near the bottom of the list is a log of the last 50 or so boiler functions - I think if there were any errors you would see them in this list.
  3. Thanks Peter really useful- and cheaper than what I found?. I guess I am going to bury it under the lawn when I reroute it so I’ll probably go heavy duty just in case
  4. Whilst I like the idea of sinking the pump Peter, I think its likely that I'll move the pump further to make sure. Having had a quick google, I'm not clear what sort of tubing I should order for the pump, and also connections etc - could someone advise please - will Screwfix have anything or do I need a more specialist supplier?
  5. Hi all thanks for your responses. Sounds like plenty of options so I'll try to figure out the best
  6. Hi - we have just had a sewage treatment plant installed replacing an older one. Little did I know that the air pump would be housed on the outside and it makes a low level humming noise that is going to be a problem for my partners sleep ?. Its a PC4 Marsh Treatment Plant with a Secoh pump. I asked the guys if the pump could be moved away and they said no, but having read other threads on this forum Im not so sure. Can anyone confirm that I can move it - say about 10 metres away? Will it be detrimental to the pump in the long run or anything else I need to be aware of?
