Doodlehime
Everything posted by Doodlehime
After some digging the answer for those interested is that they are the same product.
- 1 reply
- 4
Would anyone know if Knauf Eko Roll sold in B&Q is the same as Knauf Loft roll 44. They seam to have the same thermal conductivity/R value and cover the same m2. There is quite a difference in price however so wondering what would be best to for using in a loft. Knauf Eko Roll Loft insulation roll @ £19 per roll Knauf Eko Roll Loft insulation roll, (L)7.28m (W)1.14m (T)100mm | DIY at B&Q 100MM LOFT ROLL 44 LOFT INSULATION @ £32.22 per roll 100mm Loft Roll 44 Loft Insulation SL 8.30m2 Pack (beesleyandfildes.co.uk) I have noticed Wicks have their own range of Knauf too which is even cheaper: Knauf 100mm Space Bottom Layer Loft Roll Insulation @ 12 per roll Knauf 100mm Space Bottom Layer Loft Roll Insulation - 8.3m2 | Wickes.co.uk
Joiner came and to check over. Agreed that its not doing anything. If really wanted to brace further up (I’ll attach pictures later for anyone interested). New hangers in so finally I can think about putting a proper hatch, ladder and lots of insulation in. thanks for advice.
There is only one and its got no tension on it at all. Joiner friend of my father in law looked at it today, suggested placing them higher up out the way if needs be and taking this one out the way.
Hi looking to make some storage space in my loft but maintain the correct level of insulation. We will probably build a bit of a floating floor but either way this timber is in the way. Its crudely nailed in place. Is shakey as anything and at some point looks like its been cut and patched up again. My question is what is it and does it need to be there? Was it there to hold the perlins in place while the roof was constructed but could now be removed? Would it still be advisable to secure the same trusses further up near the ridge line. thanks IMG_7267.MOV
We want to install EWI on our house. The soffits are due to be replaced this week as part of a new roof. Next door has had EWI replaces already as part of a gov scheme and I noticed rockwool has been placed in the soffits. the EWI would when retrofitted come below the soffits but I assume this would leave a thermal bridge band of around 6-9 inches around the top of the wall in the affected external walls. Would it be advisable to use rockwool or PIR behind the soffits now before they are finished?
The job I have been putting off! Dropped all the old lath ceilings in our house reno last year. Nows the time to think about putting them back up. Problem is the floor and ceiling joists are all over the place. A builder recomended battening the ceiling perpendicular to the joists and packing them out to get them level but I am not sure what size of batten to use and if rough sawn would be acceptable. Would be looking at 12.5mm plasterboard at a minimum. Any advice much appreciated.
Perfect thank you. I will check it out
Wanting to design UFH for an ASHP system. Would anyone know of a program I can load architects PDF design into to sketch and accurately measure UFH loops in? Cheers.
Any experience using spreader plates?
Doodlehime replied to Doodlehime's topic in Underfloor Heating
I have looked at those yes but i think quite expensive also the skirting was metal if i remember and i just didn't like the sound of what is essentially hollow trunking around every room. -
Looking at feasibility for spreader plates fixed to the underneath of 22mm floor boards in upstairs bedrooms and bathroom (tiles and laminate to go above). ASHP as heating supply. 100mm PIR under the spreader plates held in with batten. Wondered if anyone had done a similar thing and what their experience was like?
Good point.
? Im sure my father in law who is helping me would love to do it. In all honesty we dont have the time or budget to dig up the whole down stairs. Also as these wont be living areas I think it would be over kill for our ex council house. One existing concrete floor does need to come up because I believe it has suffered from sulphate attack. Also the DPM which was bitumen poured on top has been breached and the floor is seriously bad. From what I can see the solid floors in the unshaded areas are all good. If people think UFH is not an option in these areas I will us rads and hide the pipework in the new stud walls.
Sorry for the crude drawing. The areas shaded in green will have insulation to Current building regs and UFH. The area in question is the hall which from what I can tell is an uninsulated slab.
Ok thanks all. Would a radiator in the space be more advisable then?
Sorry I don't want to raise the floor as it have to follow that through all around the down stairs
Ive seen the Wunda system but ideally id like to not raise the floor.
So it would only be in a narrow hall space. The living spaces will be part of an extension and have insulation underneath.
Looking to retrofit UFH into a concrete floor in our hallway. After talking to my heating engineer he mentioned a company which can mill the tracks info the floor. I looked to hire the machinery myself but few companies in the country rent the gear and none in the north west. I wondered if I could use a wall chaser to do a simple 17mm channel in a simple grid and then use a hand chisel to round the edges off for the turns?
Hello from a 1950’s concrete block renovation
Doodlehime replied to Doodlehime's topic in Introduce Yourself
I’d be paying for insulation on a professional job though anyway as it was costed into the price. Id calculate for the size of the room insulation at around £400 and thats for 100mm Kingspan. Should be marginally less if going for a different brand? -
Indeed. I had one damp course guy say he would dig it out and put in a timber floor until I took him outside to show him where ground level was and that there was no space for air bricks. He said he would dig a trench in front of the room 13 inch deep for the air bricks. I didnt take him up on the work. Someone else quoted nearly £3k to redo the floor. Im going to do it myself and hopefully save some money in doing so. -
Purchased a 1950’s ex-council house in the summer. Currently stripping the house back to the brick (or block) with an aim to modernise, insulate and build an extension (sadly not self building the extension). We have hit few problems so far apart from a bulging concrete floor sitting on earth which we will need to dig up and renew with a new slab soon. Still waiting on plans to be approved for the extension, keen to use Durisol blocks for this due to speed.
