Hi there, I'm not sure if this is posted in the correct section or if I need to post it in the timber frame section.
	My question regards the 3 no 150 x 50 timbers which seem to be vertical in the drawing at the top of the walls. This is a first floor timber frame extension on top of an existing brick and block wall. Reason for timber frame is the cavity is only 50mm. So has to be done this way for U value. Is it normal for the timbers this way Vertically as I have normally on all the programs and books is Horizontal and the timbers overlapped at the corners. The wall studs are 400 centres as well.
	Thanks
