nicktwick
Everything posted by nicktwick
  1. I've gone digging again for where I saw the condition about foundations. I thought I was going mad but eventually found it... From https://www.homebuilding.co.uk/demolish-and-replace/ "In order to qualify for 0% rated VAT, the entire existing building including the foundations must be replaced. So if you keep, say, the existing substructures, you won’t be able to reclaim the VAT, which adds a whopping 20% onto the construction cost." I can't find it in HMRC guidance, but I did see this: https://www.gov.uk/vat-builders/new-homes "any existing buildings on the site have been demolished completely to ground level" 'Ground level' suggests removing the piles. If it was 'ground floor level' I'd read it differently. But "retaining the ground floor slab" is a well noted exception. Essentially I'd be losing every wall of the existing building, but technically speaking not going down to ground level.
  2. Hello all I have a 1960's riverside bungalow built on a concrete slab, raised about 4 feet above ground level by concrete piles. I am looking into getting the piles surveyed, with the idea of building a new dwelling on the existing slab. This is only really an option I want to explore if the build would be VAT free. If it's not, I may as well take up the piling too and start from scratch. However I'm confused as to whether it would be subject to VAT or not. The HMRC guidance suggests if you retain only the ground floor slab of a building then you can avoid the VAT. But it also goes to lengths to say you can't retain existing foundations. Do the piles count as foundations from a tax viewpoint or not? Grateful for any advice. Please feel free to indicate if you've had experience of anything similar. I will get pro advice before the build, but in the meantime would like to feel quite confident about this point.
