Yes wiring is all low voltage, it comes with pre made wiring loom and you can run 20 spots per feed
Cabling was a bit tight on the corners but managed to space it all evenly
https://www.saxbytrade.com/products/exterior/decking
Nick, kept the steels exposed as was the look we wanted
Still need to find a company to sort the triangular cuts as local places saying job is too small
Matt, yes they are limestone from forest stone
https://www.foreststone.uk/product/blissford-tumbled-limestone-paving/
Finally got the remote control power supply installed yesterday
3 spare outlets now for lamp post and garage up lighters
Spot lights in the sleepers turned out well
Not yet Gaz but we are going to do it
Few bits to finish it off really
-Need the decorative stone between slabs and sleepers
-New socket/ control box wired in to control lights
-Top soil and about 50 lavenders for planters plus some turf to blend lawn in (guessing I need to crack on with this now or leave it until spring)
All finished a while ago
Pleased with it all, the flow point ultrascape does seem patchy in a few areas but had heavy rain a couple of hours after final section was complete so not sure if that was the cause
Been away for a week but guys are cracking on with the patio and doing a great job!
Decided on offset bond rather than brick bond, really pleased with it.
My choice to break bond behind the garage as won’t be seen and saves me some slabs/ losing more of the garden to keep bond (retaining wall would have to have been further back)
Gone for mid grey grout and will use a similar colour for the decorative stones between slabs and sleepers (stones as allows sleepers to move a little and didn’t want any cuts along the back edge!
