connick159
Everything posted by connick159
  1. we are on direct debit and pay them the same date every month. So only have this months due which I thought we could settle via the switch request with Octopus. I'll call Tomato tomorrow and see If i can settle up and then get them to approve the switch. If they don't then I'll just wait for Ofgem to do the change to SOLR and go from there. Thanks for the replies
  2. Do you mean I could just hang around with them until the very last when Ofgem (or whoever does it) shuts them off fully and I get moved to someone else? I actually signed up to switch to Octopus Cosy earlier today but received notice from Octopus that... "Your previous energy supplier has objected to your electricity switch... We can't complete your switch until it's sorted and unfortunately it's not an issue we can resolve on your behalf. There's a few reasons why this may have happened: There's an outstanding balance with your old supplier. If this is the case, you'll need to settle the outstanding amount or agree a payment plan with your previous supplier before the transfer can continue...."
  3. Administrator now appointed. Last chance to get out.
  4. Thanks heaps for the info. Not sure if i habe a buffer or its just an expansion vessel. Also, not sure what a strainer is but all the other stuff makes sense. I have manual mixing valves on both manifolds and pumps on both manifolds too. Not sure if i need them but the UFH guy installed them as standard. We had one guy do the ufh and screed and another mob do the ashp. Looking back, should have gone with the one mob. Thanks again.
  5. Does anyone know the required steps to "unpick" a setup where the UFH8 wiring center and stats in every room have been installed? Is it a simple matter of removing actuators or do you meed to do something else?
  6. https://www.ofgem.gov.uk/publications/tomato-energy-limited-provisional-order I don't understand it tbh but seems they are in a bit of hot water. Im a customer and its been good since i joined in Feb. No probs or hassle at all but perhaps thats just around the corner given the ofgem order.
  7. Full accounts were provided on 7th Feb by the looks of companies house register.
  8. Just for Info for anyone still considering switch. I just switched from Octopus Agile to Tomato Lifestyle (battery, although we don't have one). I modelled my usage data for Jan before switching. For 896.376 kwh consumption in Jan Octopus Agile actual cost was £213.69. Tomato cost based on agile usage data = £133.80. Saving of £79 for Jan alone so... I did the switch via the tomato website. Switch took 5 days, was very smooth, no issues for us so far. 1st day on Tomato and we used 29.432 kwh - cost £3.30. Previous day on Agile we used 28.22 kwh - cost £9.20 Hasn't been many cheap days on agile last couple of months. We have a heat pump, no solar, no batteries and we try to load shift and use the ASHP over night when cheaper. We have underfloor heating in screed so we 'charge' up the slab over night and also now in the cheaper slots on Tomato which is 9:30am to 11:30 am as well as from 10pm to midnight (14p). No battery for storage or anything either so, if we did have a batt it's be cheaper still. Our kwh has gone up from around 30 to 33-35 but our cost have come down from anywhere between £7 and £9 per day down to £3:30 - £4 per day. Hope that helps anyone in a similar boat. (So far so good for our switch from octopus agile to tomato.)
  9. Do you have batteries and PV which would be factored into you cost or just an ASHP only? I'm looking to switch as well. Only have ashp and are 100% electric for power and heating. Diolch
  10. Would cosy be worth switching to, from agile, without any batteries? We only have the heat pump and nothing else. Will have a look at tomato too. Cheers
  11. Good to know, thanks. Is there any publicly available info on this?
  12. Hi all, Considering a switch from octopus agile to OVO with heat pump add on. We already have a smart meter and E7 so wondering if any experience / advice here regarding the best tariff for the baseline OVO tariff? Was looking at the "simpler energy" one via direct debit but notice they also have the PAYG tariff with day and night rates similar to the "simpler" one. Any thoughts or things to look out for. Anyone on this heat pump tariff with thoughts? Thanks in advance.
  13. is 1:80 fall adequate for next to the house? a bit of mixed info out there.
  14. Here is the alternative i've thought of. This red lines are channel drains. Pink line is a french land drain drain. Thick red lines fall of land. Blue lines are fall on the patio. Which would you do?
  15. Hi all, I've got a concept design for a large patio area but struggling to work out if I should be falling the patio away from the house, which means its working against the natural slope of the land. i.e. is that even achievable? The blue arrows are the way i want to fall the patio as its away from the house. The orange asterix is 12 metres from the opposite corner of the patio (under the trees opposite) The red arrows are the natural slope of the land. It not a massive slope but if I do a 1:80 fall it means that the end closest to the steps need to be 150mm higher which then starts making the steps too steep over that area. One idea i had was to put in a channel drain just at the top of the steps, right across the patio and then using the natural slope of the land to direct the water into the drain. (There will be another drain at the bottom of the steps with the lower patio by the house falling towards that) Would love to hear the thoughts of members as to how they've handled similar design for draining on large patio's with the natural fall going back to ward the house. Is the top patio far enough away from the house not to worry about the fall going towards the house?
  16. I've now done this and rebooted the system. No change in that 2nd UH8 still not putting the pump into heating mode when stats calling for heat. Does it automatically set 2 zones once the dip switch turned to on or do I need to do that via the main controller too? I guess the other option could be to connect both UH8s to IN1 right? Is that doable. Cables are pretty tight as is tbh. This is the option from the instructions that best represent what I'm trying to do.
  17. This happened. The stats on UH8 number 2 are calling for heat and the pump on that manifold is running but... The ASHP itself is showing as Paused when I look at the main controller. The flow pipe is pretty cool to touch too so the heating is not running. As soon as I call for heat again on the controller connected to IN1 the heatimg fires up (the play symbol is displayed).
  18. Hi Simon, Thanks for the continued support in this... Much appreciated! Where they were connected before, to L/N/E block, they were reading 5.7v. After moving to IN1 and IN6 on FTC6 they now read 0.012v or something like that. Now on the L/N/E it reads
  19. Thanks Gary, the FTC6 the terminal block looks slightly different but I've now removed them from TB2 and into IN1 and IN6 as per pic. Turned all power off to do so and when powered back on everything is up and running again. Heating and hot water flowing to both manifolds Interestingly, back on the UFH, when measuring the voltage on the heat enabled, it now reads 12v where as before it was 5. When checking voltage on the IN1 and IN6 on FTC6 they now read 0.012 or something like that. Where they were connected before, to L/N/E it they were reading 5.7v.
  20. Thanks Gary, Only a single zone at moment. The question I have is about the actual wiring task. The guidance is to wire them into the terminal block on the FTC, which I get. What I'm unsure of is which of the 'strands' within the "heat enabled" cable from the heatmiser controller controller go into the terminal block (there are 3 strands (Lr/Ls/E)) so which ones go to terminal block? Cheers
  21. At the UH8 controller, With the multimeter, when holding the red probe on Lr and black on Ls there is 0 volts. If I move one probe to the earth I get 5.7v when it's calling for heat. Same numbers where they connect at the FTC end. Is it a matter of moving the Ls and Lr on the FTC end into the terminal blocks IN1 and 6 as per the manual? I assume I can leave the earth as it is.
  22. Nothing at all from uh8's connected to the terminal block. Both wires in from each uh8 connected to the same spot on FTC as in pic. Not checked the voltage back on uh8 when calling for heat. I have a multimeter somewhere so will do that tomorrow. Thanks again. I'm baffled as the heating is working and each manifold getting heat when calling for it. Obvs not right though.
  23. Nah it's deffo black cable at the uh8 end. It also had a label on it at FTC (just below my finger) "Heat enable 2." Hope it's not a totally wrong type of cable he's used as it'll be a bastard to chase a new one between the two points. On the other end, the heatmiser UH8, the brown is connected to "Ls" the green and yellow is connected to "E" and black is connected to "Lr".
  24. On the other end, the heatmiser UH8, the brown is connected to "Ls" the green and yellow is connected to "E" and black is connected to "Lr".
