Gballam
Everything posted by Gballam
  1. Aiming for near-passive (and hoping to have walls around 0.13) so will need both internal and external the hybrid design
  2. Thanks all, very helpful thoughts. Yes I have been wondering whether a hybrid wall of 60mm woodfibre outside studs plus the mineral wool and then pir inside studs is more achievable
  3. The why is trying to avoid thermal bridging without a twin frame. The issue is the complexity!
  4. Has anyone built a wall build up like this? Any thoughts? Walls – U-value 0.12 W/m²K Internal Finish: 12.5 mm Plasterboard Service Cavity: 50 mm battened void (filled with extra mineral wool?) Airtight & VCL Layer: Pro Clima Intello with joints taped using Pro Clima Tescon Vana. Structural Frame: 140 mm timber studs. Insulation: 140 mm full-fill mineral wool cavity insulation (e.g., Knauf RS45 or Rockwool RWA45). External Sheathing: 9 mm OSB3. Breather Membrane (Frame): Protect TF200. EWI: 160 mm high-density mineral wool (e.g., Rockwool Frontrock or density-equivalent RWA45 slabs). Weather Seal: High-performance W1-rated breather membrane (e.g., Tyvek Housewrap) installed over EWI. Cavity Fixings: Thermally broken structural insulation screws (e.g., HECO Topix-Plus Therm) installed at a 60–67° angle. Screws must achieve a minimum 50 mm embedment into structural timber studs. Ventilation: Horizontal structural battens (min. 38x89 mm) + vertical counter-battens Fire Safety: Euroclass A1 non-combustible cavity barriers. External Finish: Cedral Click vertical cladding + starter/top profiles + vermin mesh.
  5. Hi helpful people from last month, I've been playing around with facade options to try and address the massing issues. Done in budget-version HomebyMe so visuals a bit unrefined. Wondering about removing the standing seam and switching it for slates on the roof. Then a half render/composite cladding for the walls. We've also pulled across the porch a bit make more of a feature of the asymmetry, get more light and views upstairs and create a porch. Floor plan change shown here too. Any comments on this? Is silicone render on a timber frame really flexible enough to tolerate the movement!? Many thanks for your wisdom
  6. @garrymartin Thanks Garry for your thoughts. Keen to keep the plant room window as we’re going to have laundry drying space in there so will be in and out frequently. Good point that widening the little projection (and door/glazing) would add more balance
  7. Yes I’m not sure why the first floor looks to be wider than ground - it will be ever so slightly due to the metal cladding but not as it looks here. We thought running the metal cladding down around the front door projection would help the two sections mesh together better. It’s the same as the roof - not the orange Corten. Here are the other versions from the architect…
  8. @Gus Potter Many thanks for explaining this - I had assumed massing meant it’s all in one block, rather than the materials. Due to the slightly uphill, wooded and curved approach of the track leading to the house, the roof will hardly visible on approach. We included the half wall of metal cladding to break up the front facade which otherwise we thought was too blocky. We also thought a darker colour at the bottom (such as Metal Green Cedral Click) and then a lighter roof zinc-coloured steel roof would also help. We’ve played round with lots of variations and materials and are struggling to know what looks the best - if you/anyone has any suggestions on improving the front facade then we’d welcome them!
  9. Thanks so much for sharing those pictures, so helpful to see. Agree - sofas are much better as they are now
  10. @Kelvin Many thanks for your helpful input. I’d be really interested to see the pics - and of your kitchen if you don’t mind sharing. Even with online 3D models, it’s hard to fully imagine the space
  11. @-rick- Very observant with the flipped design - that’s exactly what happened and the down pipe has been left on by accident. Need to look into downpipes clearly! Still very early to fix. Pleased there’s things here to inspire your design The dining table isn’t drawn in the right place - it will be moved towards the kitchen slightly and therefore there will be a bit of circulation space on entering the main room. We will have a behind the sofa sideboard to create a bit of room divide/conceal the back of the sofa
  12. Thank you - v helpful!
  13. Thank you so much for taking the time to draw this out, we will mull over this change
  14. Thank you - this is really helpful. I hadn’t thought about the tunnel effect and it would be an easy improvement to move the snug/cloaks walls back a bit
  15. Thank you. It will be in the middle, architect didn’t update that part
  16. Yes we also thought a nice feature to have higher ceiling height in the main living areas. We hope to be able to afford a warm roof and have most of the upstairs vaulted - with the exception of the dressing and the master en-suite which we plan to have flat ceilings for storage above. We want to try and make what is essentially a box and a lid a bit more interesting internally!
  17. Thank you - noted. That’s encouraging
  18. Hi Bonner, Thanks for your reply. Why in particular would you caution against the split level? Our site slopes and it will allow for flush entrance at the front and back. Georgina
  19. Thanks v much for your reply. Noted re: soundproofing and hadn't thought about the noise of the pocket doors. Yes - agree with the sink/hob on the island, not sure why the architect drew it like that. It will just be a centralised hob on the island. Will have to think about SVP route. Thanks again for your thoughts
  20. Hi all, We are trying to create a thermally-efficient, cost effective family home and the comments here are always helpful. Please let me know thought on this design. We're thinking Cedral Click in Metal Green for cladding and a light grey standing seam steel roof/cladding on the front facade. Many thanks :) House plans.pdf
