Junglejam
Personal Information
  • Location
    Dorset
Junglejam's Achievements
New Member
New Member (2/5)
0
  1. Has anyone used floor paint as a finish on their floor? Due to financial constraints, we want to paint our floors with a decent floor paint for sign off, and when we’re ready in a couple of years get the flooring we like. Onto concrete with UFH.
  2. A wood burning stove question for those building an air-tight, self-build house with MVHR, I have two questions: 1. What is your stove of choice, as needs to be direct feed and air tight to not affect the balance of the MVHR 2. Can you self-cert/install, letting building control know you are doing so and signed off on completion of build?
  3. The calculations were reached through timing of water infiltration of soil (water does pool after down pours) and 1 in100 year event of flooding. There is no road drainage or sewers nearby as we are out in the sticks. However, there is an open ditch that runs along two sides of the property (just outside the plot) and onto the lane and this could act as a storm flow if connected. I suppose what I really need to know - do planning check whether I install all 200 crates or not!?
  4. We are nearing completion of our self build and one of the last major tasks is to install the soakaway for rainwater. Prior to starting our build we had to carry out a percolation test and provide a scheme for dealing with the surface water and this was submitted and Discharge of Condition was approved by the Council as part of our PP. However, our percolation test result required a whooping 40m3 of soakaways to cater for a roof size of 120m2 plus 45m2 for the double garage. I've spoken to the firm who carried out the calculations a couple of times and they verified their calcs are correct. Installing a green roof or rain harvesting tank would not offset this at all. Building control will return to check for underground drainage of pipes and inspection chambers but are not really interested in the number of crates installed. My question is: when does planning get involved with this? Do they check what is installed before I cover over....?
