charleee
charleee's Achievements
New Member
New Member (2/5)
0
  1. Hi, It's been a while since you commented this but was hoping if you could help me out?:) I'm planning a dropped ceiling from the current concrete ceiling. I have found British Gypsums systems and as you mentioned "Gyplyner" sounds like a very simple, easy solution. However, there's also a system called "CasoLine MF". Do you know the difference between these two systems? The Gyplyner ceiling is more simpler and allows more room above the ceiling with less drop. Planning to finish with plasterboards and since you have used this I was wondering if the Gyplyner is enough for residential flats?? Thank you in advance!
