Ade
Everything posted by Ade
  1. Hi, So I have a Kinetic Plus B (443028), from some 10-12 years ago. Same issues / results as seen as above. Some mould inside unit and on Heat exchanger cell. Not the easiest to clean! Broken end panels of Heat Cell where joining to body of Heat Cell. And some elements broken. Can be glued successfully with plumbing pipe solvent glue :-) Torn seals - Thanks for identifying "neoprene adhesive backed tape" Will now source. Broken "teet" on Bypass actuator - See below. All else (touch wood) still going strong) My actuator is 100331.27K T105 I have managed to break the "teet" off the end that engages to the summer bypass mechanism. So looking around: £50ish: https://electricspares.co.uk/product/vent-axia-actuator-kinet-airminer/ But how about this: £14: Got to worth a punt? https://www.leisure-parts.co.uk/thermoactuator-eltek-b10-kt105/product.pl?pid=10656 UK seller of Eltek https://www.radward.co.uk/eltek/10033127k Aus Ebay - but used in other products, which might help. This has the same "teet" as mine did.... https://www.ebay.co.uk/itm/143189739579 But I haven't worked out all the product coding as (all these - at the "right sort of price", have different ends): https://www.ebay.co.uk/itm/405603465584 https://www.ebay.co.uk/itm/356691708759 https://www.ebay.co.uk/itm/205336941517 Hope this helps. Ade
  2. Hi, Signed up specifically to reply to you - as I have similar issue and found your post via google.... So I have a Kinetic Plus B (443028), from some 12 years ago. The actuator is 100331.27K T105 I have managed to break the "teet" off the end that engages to the summer bypass mechanism. So looking around: £50ish: https://electricspares.co.uk/product/vent-axia-actuator-kinet-airminer/ But how about this: £14: Got to worth a punt? https://www.leisure-parts.co.uk/thermoactuator-eltek-b10-kt105/product.pl?pid=10656 UK seller of Eltek https://www.radward.co.uk/eltek/10033127k Aus Ebay - but used in other products, which might help. This has the same "teet" as mine did.... https://www.ebay.co.uk/itm/143189739579 But I haven't worked out all the product coding as (all these - at the "right sort of price", have different ends): https://www.ebay.co.uk/itm/405603465584 https://www.ebay.co.uk/itm/356691708759 https://www.ebay.co.uk/itm/205336941517 Hope this helps. Let me know where and what you do. Thanks, Ade
