Fiona Brick
Fiona Brick's Achievements
Member (3/5)
2
Condensate Drain Pipe
Fiona Brick replied to Fiona Brick's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I agree Nick and this is what we were happy to do. However, when I saw water at the base of the unit, I contacted the agent for the unit who designed and commissioned the system. I didn't know where the water was coming from initially. They said one of their plumbers would be passing and would call in. He identified air tightness measures had blocked the pipe outside which caused the water. We were told to contact a plumber to re route the condensate pipe to the sink outlet and put a trap on it. We then got a bill from them for 180 as they said its not a unit related issue. We didn't expect this bill given that we're going to be paying a plumber to reroute the pipe anyway. It's a bit frustrating as I feel they should have checked this on commissioning or at design stage. The plumber who installed is one of their contractors and was involved from planning stage. Anyway, as you said, easier to just get on with it at this stage. I'm learning more and more everyday, unfortunately some of the info is being learned too late 😪 -
As Conor said, it does appear that these are service pipes and a service gulley and are in fact nothing to do with waste water. Not sure why the condensate pipe was run into these and especially when run with no trap etc. -
I think you're on the money Conor, not sure why the installer did this. There's a sink outlet on the other side of the machine connected to the waste water system that should probably have been used.... -
Should this have been checked/picked up on when the unit was being commissioned? -
This is the inside of the unit where you can see the piping which i presume has an overflow tray in the upper section. It's an MVHR with integrated 2kw heat pump and 180l hot water cylinder. One of the pipes is where the WiFi comes in - ones on the right, one is where power for a shed and electric gate will come in red ones left and middle. Middle brown is currently blanked. That's why I'm confused with condensate drain as none of the red are waste pipes to connect condensate to 🤔 -
Kind of runs nowhere at the moment....it's installed for connection of a possible back up air to air unit... -
Fiona Brick posted a topic in Mechanical Ventilation with Heat Recovery (MVHR)
Hi All - advices appreciated. We're new to all this and still gaining an understanding of our unit and it's installation which we had done professionally. I'm going to post a pic of our condensate drain pipe internally - pipe sitting loosely into 1.5 " white pipe which feeds into a brown 4" pipe. This 4 " pipe runs internally to externally and was set in concrete and insulation at foundation stages. It does not seem to link up to anything or have a soak pit etc. outside. It's the one furthest on the left in the pic. There also do not appear to be any traps internally. Is this normal? I'm concerned re rodents/ice formation/cold air ingress. -
Thanks for that. We're just at the point of going back over the pipes and doing further insulation. Thinking of overing with wool insulation and boxing them in with PIR. We have another section of the house where ducting is within thermal envelope and no issues with that vent air temp.
Hey, what changes did you make? We also have some of our duct work running through a cold attic space and we are experiencing really big temperature losses at the supply air points serviced by this duct work.
Cold Air
Effectively an installation issue then as the supplier/installer was the person doing all the duct work too? -
Cold Air
Our estimated heat demand at the outset was expected to be 5kw during the coldest winter months. This was based on an airtightness test of 3.0 and a room temp of 21. We achieved an air tightness of 0.882, are A rated in terms of Insulation (ICF house) and took thermal bridging measures throughout the build. We have a vaulted space in the living room which was pointed out as being an area of concern. However, this isn't the area that is causing the issue. This area called for very slight additional heat during the cold snap we had but still maintained a steady temp of a min of 17. We are very open to putting an additional heat source here. The system itself has a 2kw integrated heat pump so in current weather conditions, it should be meeting our needs. However the area we are having issues with was never considered to be an area of concern by the supplier/installer. We were certainly never expecting it to be blowing cold air so frequently. My fear is that if it is an installation issue surrounding ducting or a mis calculation at design stage, supplementary heating will not address the issues in this section of the house as any supplementary heating will be counter acted by the constant flow of cold air and will end up costing an arm and a leg. -
Cold Air
Ducting is by the same person, our supplier/installer. -
Cold Air
Thanks for that John. This is exactly what I was thinking having observed and monitored the system in different operating states and external weather conditions. Thankfully the house is performing well so just need to get this aspect of things addressed by the supplier/installer. -
Cold Air
I should have explained that the run from the machine to the areas where we are experiencing cold air is a relatively long run and passes through a cold attic. My guess is inadequate/poor insulation on the pipes and manifolds in the attic and/or a miscalculation at design stage of the heat loss per linear m. This is what I am requesting the supplier/installer to investigate and remedy. I guess what I'm trying to ascertain is, is it normal or to be expected in anyone's experience that there would be such a large temperature differential? -
Cold Air
The MVHR unit has a counter flow heat exchanger and an integral 2kw heat pump. The integral heat pump heats the water and the supply air. Obviously as a 2kw system, we never expected it to meet out full heat demand albeit it wouldn't be far off. However the air supply temperature differentials in one part of the house v's the other is what is causing concern. Any additional heat sources will struggle when operating against an often constant flow of cold air. This is the issue we are trying to address and solve.
