J-P
Everything posted by J-P
  1. I also have a leak from a Vent Axia Kinetic Plus, water trickles out from the front and sometimes from the back of the case. Drain pipe and trap appear to be clear. The problem seems to stem from the poor design of the the cell/unit in respect of condensed water; it just has to find its way out of the cell, past the summer bypass and down the drain. There is a slight fall on the foam insulation that the bypass mechanism sits on but nowhere near enough to ensure water runs into the centre of the unit and then down the drain. With high levels of moisture and cold weather I e. winter, water just spills out in all directions! I think a proper solution would require modifications to the cell and the summer bypass to provide a decent route for water, in the meantime removing the summer bypass unit in winter solves the problem (making sure to insulate the 2 power connectors).
