I am in the process of refurbishing a 1980s timber framed house and will be replacing the existing (knackered) tiled roof with a pitched warm roof finished with 13/3 corrugated metal.
I've attached a drawing of the proposed layup of the roof (which I hope is clear enough!). The roof trusses will be left exposed and the bottom layer of plywood will be fireproofed and lacquered and will be left visible from the inside. As the roof trusses are a pretty skinny 38mm, I'm planning to screw a wider vertical batten above the plywood into which the layers above will be fixed, as I don't fancy my chances of hitting the trusses with screws through 200mm of insulation.
I'm looking for some advice on the fixings to use and how many. I was planning on using thermally broken fixings as shown in the purple in the drawing, going through the counter batten, osb deck and PIR insulation- which would need to be about 250mm long. However, I'm wondering if I can just fix the OSB deck in this manner and then just screw the counter batten into the OSB? If it's sufficient to just fix the counter batten to the OSB, then can anyone give me a ballpark figure for the spacing/number of screws needed or how to work this out? Any tips on thermally broken fixings and screws for the battens also would be much appreciated. Many thanks.
(Apologies, if this has been covered before and thanks for all the amazing advice from everyone I've read so far!)
