Kim
Everything posted by Kim
thanks all. not changing the white UPVC windows - they will stay the same to match the existing house - this was the only colour stated in the planning documents. no conditions in planning consent - no material samples submitted - just architect made everything white as standard. I think i've decided to do it. I cant see how colour has any reflection on the build itself, i suppose i can paint them white if they get fussy.
Hello All So i have full planning permission to build a house on the side of mine (also being renovated) and build is now up. Builder pointed out that the front doors and bifolds on both properties in the planning drawings (attached) are white. I want anthracite. It states White UPVC windows but other than the visual drawings it is not stated what colour they would be only the specification required from Building regulation drawings. I contacted the council to ask and they said put in a non-material amendment form to the original planning permission which means £234 plus £40 for architect to change document. Are they serious? It is a council estate where everyone has what the hell type and colour doors they want. Would you just put the colour in that you want or pay and do all this work? Couldn't they just be changed after everything was signed off anyway so why would they refuse if it is at the specification required in building regs. No grade listing and not in a conservation area. I really have to save money here and this just seems utterly nuts. Your thoughts? 107_PL10_PROPOSED_ELEVS.PDF
I think its quite cheeky I'm going back to the builder to find out breakdown
yes space consulting structural engineers Just had another quote for £1300 as the welding is two guys welding whilst steels in position on site and the plates are £150 each Its not seeming so bad after all
cavity walls the steels went up today by my builders My architect designed everything and building regs missed this (got the right steel though) he even remembered the steel plates required for the extension picture frame but not the internal ones on both house
SE coming out tomorrow. but its all been agreed with architect and BRs guy who fucked up in the first place.
sorry should of said.. this is an internal picture frame at the back of the house before a single storey pitched extension on the back. This is for two houses as well. This was missed by building regs ? and only included the plating for the external walls. The walls are 325 and the steel columns 203/203/60
oh i hope the other one doesnt mean i have to pay CGT until i sell it? it was my primary residence for over three years.
Hi all. My builder gave me this quote today and i had no idea it was coming. If you're in the industry could you take a look and see if this sounds right? Two steel plates are required to be added to the top of the steel frames.They will be welded on site. Reason:This is to carry and support the wall above. The wall is 325mm wide and the steel is only 203mm wide and that is why it is necessary to have the steel plates welded to the top.2 No steel plates @ 325mm x 10mm x 5.3m Welder required on site to weld the plates to the steelSupply and installationTotal £1,495.00 Thanks so much for any help given x
oh bugger i put it back. I think it was a 400mb file for each day
Moving into the new build and renting out the renovation ? had a little Tax advice, no CGT as will be my residence, VAT exempt on New builds and no stamp duty on new builds. This will be our home. The residential mortgage on the renovation is sitting at a good LTV and will allow BTL after project, will convert to a BTL mortgage in 2 years when expires ? Well I hope that's all right anyway Thanks for saying i'm brave, but shitting it most of the time ?. Especially when an unexpected £3500 bill comes in for something Building Control missed ? if they don't catch it then the builder and I sure as hell aren't ?
im paying for infinity so its 20 years warranty but will definitely check
wow, thanks for all the responses all, its really interesting reading everyones experiences. I have committed via deposits on each kitchen to secure all the January discounts even if i make changes in May it will apply and i will be entitled to any better discounts if/when they come out. I have paid the Building Company to fit both kitchens and will be with there reputation and warranties obviously. Wren weren't bothered by this at all when i said that. The work surfaces are fitted by there Quartz company though.
B&Q already come up £8K for bigger kitchen plus i would have to get all appliances myself it will be about same as Wren. With Wren i got all CDA appliances with 5 years warranty. It does seem like Luck with Wren though.
Thanks all They are refusing to let my builders do any of it and will only accept an ICP that they approve, they sent me a list Break down as follows: Description of work to be carried out by you ("Your Works"): These will be described in the Customer Responsibilities Document that will be issued to you by UK Power Networks after the site visit. These works may include (but are not limited to): - excavation and reinstatement on your property; - excavation and re-instatement of the joint bay in accordance with our instructions and the booklet "Avoiding danger from Underground services" 9HS (G) 47 published by the Health and Safety Executive; - supply and install of electrical duct; - arranging for third party consents where required; - internal electrical works to British Standard BS7671; - appointing an electrical supplier; - supply and installation of a sub main; - supply and installation of a meter cabinet/cubicle; - supply and installation of meter tails and earth wire. Connection Timescales: Provisional Completion Date: 30/04/2019 (*)This date can be altered to suit your construction programme. Description of the Works to be carried out by UK Power Networks: New Single Phase Service **Subject to Wayleaves** **Subject to customer completing all excavation on their land** **Subject to customer installing a meter box and hockey** The connection of a new underground 100 amp single phase service onto the mains. Includes excavation and reinstatement of a hole in an unmade surface, verge or grassed area to expose the existing cable in order to connect the new service. 1471.00 Excavation and reinstatement of low voltage service cable in an unmade surface, verge or grassed area. This includes the provision and installation of the cable and ducting and is charged per metre. 1545.00 Excavation and reinstatement of low voltage service cable in standard footway surface types such as concrete, macadam and slab paving. This includes the provision and installation of cable and ducting, and is charged per metre. 438.00 www.ukpowernetworks.co.uk Page 4 of 4 Installation of a single phase low voltage service cable and duct per metre. 20.00 Standard flush meter box to house the new single phase supply. 41.15 White hockey stick used at the end of the ducting to link into the meter cabinet to enable termination of the cable. 10.76 For the purposes of the Terms and Conditions the following elements of the Works are "Diversionary Works" Total Excluding VAT £3525.91 VAT @ 0% £0.00 Total (including VAT) £3525.91 Please note that the Price and the Completion Date are subject to the Terms and Conditions attached to
Hi Not sure if this should go here as cant find any areas to discuss utility companies. I have been quoted £3550 for my electrical connection on my new build, does this seem ok? Would you source an Independent Connection Provider (ICP) instead? or is it a waste of time? Thanks so much for any useful responses xx DESIGN.pdf
Hi I have committed to Wren in the supply of both kitchens for my build/ renovation, bad/good move? The price of the BIG kitchen with everything: cabinets, island/breakfast bar, quartz work top fitted and all appliances (price matched to AO.com) was £9700 The smaller kitchen (New build/ my house) is the same but £8600 We even left in some tolerances at all angles should the size of the kitchen change slightly (architect mess up or plastering thickness etc) I had quotes from Wickes at 12500 & 11800 respectively and B&Q was cabinets and worksurfaces only but wanted £1250 per worktop installation and not consider whole thing at same time as one job. Thoughts?
They say theyre simple but i'm struggling I have had it on a couple of months and it takes a picture every hour for 8am - 4 pm but when i downloaded I have a tiny video per day instead of one big one. What have i done wrong? I have now set it to take a photo every hour of the day in the hope it will link whole lot together but i doubt it. Any help appreciated as i have searched online and watched every video and those with the show you how to download the footage all show ONE video
Hello Just a Hi from a newbie. I have a few questions but will put them into the right areas of the forum (hopefully) Its been three years in the making and we started digging ground end of November with three weeks off for Christmas. Originally i was extending my house side and rear to transform a small three bed into a big 5 bed to have my babies in and stay a while. After lots of evaluation it worked out a little better to build a new house and only extend mine single story rear to improve communal space. Its taken a long time to get planning, split the deeds and get the Builders Mortgage sorted but we are well underway. x
