boxrick
Everything posted by boxrick
Thanks that makes sense. I'll have a think on it
Hello folks. I'm after a bit of advice, someone I was working with took on the electrics for my house. They have made it clear by their actions they do not wish to come back and I was left with a mostly first fix house minus a few rooms. I've reduced the scope multiple times and they agreed to this. But are still not coming. I've been waiting 3 months and still had nothing besides infrequent replies and or various reasons why they can't come back. I mostly paid upfront with a very small outstanding payment for full first and second fix. I'm now having to get another electrician involved probably going to cost me multiple more thousands to get it all resolved. Any sensible fair recommendations since I dont know what to do.
Whistling through expensive Norrsken front door - Driving me crazy
boxrick replied to boxrick's topic in Doors & Door Frames
Norrsken admitted they had some website errors and the door is incorrectly showing as 33db instead of the correct 22 or 21db. They are going to replace the door itself at their cost to the acoustic version but just waiting on info from them. Will update as I get more info. -
So I have some pipework for my rose / hand shower head on the wall which so someone installed and mounted what I believe may be too shallow since its going to get eaten up by tiles / tile adhesive. Can you get extensions or am I going to need to remove a bit of board and mount it sticking further out?
Securing backboxes - Plastered and proving challenging
boxrick replied to boxrick's topic in Electrics - Other
For anyone browsing this in the future these BG electric ones are fantastic. Really thick and nice, not many holes. Highly recommended. At £2 ish each also not much more over the plastic junk. I should have never really been put in this position let alone having to cut all these out, but at least these are a nice solution -
Thanks, I'll buy both sets and see which works better. Maybe foam the buggery out of them too -
Hello folks! I am currently trying to acoustically all my back boxes which with metal ones is quite straightforwards. I put caulking around the edges, pop the cable through and then add my acoustic putty to the back as shown below. The issue is with 'fast fix' boxes which have been liberally used all over. Which sadly until I was plastered didn't realise had been used so far through my build. They are littered everywhere which is very unfortunate since we literally had open studs and could have used metal ones everywhere. Anyway, right now this is presenting me a real issue since I cannot install pattresses and install the standard metal ones, I cannot add wood to the sides to screw from the front into since I am plastered. Does anyone have any suggestions? Simply put I need to get the backboxes in and fixed solid which will then allow me to 'finish' around the edges, backs and side with my acoustic seal and putty and it not move again. I am thinking some of these may do the trick which seem to have a spring which lightly clamps them in until the faceplate is installed? Or is there any available with ratcheting type lugs? Or maybe foaming the boxes in? https://www.builderdepot.co.uk/bg-2-gang-47mm-fire-rated-dry-lining-box-hgs07-fr
A small bump here.. I have cemfloor. I am about to paint mist coat and want to seal the floor. Will be a final finish of carpet / tiles / laminate depending on room. I am thinking a watered down ( 1/3 or 1/4 SBR ) and maybe a couple of coats to seal the floor?
I have passed this new info onto Norssken. Just awaiting a reply now.. -
You can see the frequency here which is almost completely unblocked. This is what is leading to the 'whoosing' sound. The blue is fully open and the red is closed. You can hear how hollow the door sounds in the centre, this is where most of the sound is coming through: -
My friend brought round a really decent calibration microphone and we measured different scenarios against a baseline. In the 1.5khz range there is basically 0 attenuation. The door is actually rated at 33db in sound reduction. But even the difference between the most drastic sound reduction is well below this. I'll share some graphs shortly. Also as you knock along the skin of the door, some bits are completely dead and others sound completely hollow. I'll share some more info when I'm at my laptop. -
Interestingly enough my friend does have a decent one, he was wondering around last week. But we didn't concentrate on the door -
Traffic noise I believe is the issue, but it's a high pitched sound which is basically created by the panel of the door. The sound is obviously coming right through the leaf. I wouldn't expect the Marmox material to make it worse given its mostly just insulation. I've got it in all the reveals for every window and they are generally fine. -
With this gently in front of the door. The majorly of the whistle is gone. Even if the door is open it's miles quieter with this random stack of Rockwool -
MVHR isn't running yet I've taped fully around the edges with masking tape and also ran a piece of paper all the way around with it shut. It's tight everywhere. It just sounds like it's coming right through the leaf. Also if you knock on it, it almost sounds hollow -
Hello folks! I have gone to fairly extreme lengths to make sure sound doesn't come into my property which included buying Norrsken triple glazed windows / slider / front door. I have filled literally every gap you could imagine in the property. However my front door is like a massive amplifier. Its actually noiser with it closed than open. See attached video show the problems and some pictures of the detailing around the door, but I would love some advice. I believe that if I had simply gone for a glazed door as per my windows I wouldn't be hearing this sound. I have gone back to Norrsken support and waiting on a response. The sound is absolutely coming directly through the leaf of the door the surrounds and roof is silent.
Finishing up boarding whilst plastering - bad idea?
boxrick posted a topic in Plastering & Rendering
Hello folks. A simple question, my plasterer is booked in. There is still a lot of boarding to do. Simply put should I get a room plastered whilst still fitting boards in other rooms? Or will the dust ruin my finish? -
Hello folks I'm about to fully membrane my ceiling before my cellulose insulation goes in. Simply put I've watched a few videos about membraning. My joiners were going to do it, but I reckon myself and my girlfriend can do a better job. With that in mind, can anyone share any resources or tips for me to get this right?
Hello folks. I have around 250mm of insulation with some water pipes underneath and UFH pipes installed on top. I've just realised I need networking / power and speaker cable to next to my sofas and kitchen island. See above pictures, do I panic cancel the screed company who are due at 9 or is there something I can do in a few hours before they arrive?
The roofer suggested lead valleys too. Think that's probably the way forwards! Cheers for the extra input.
Hello folks. I have a roofer due to come today and I ordered a "closed dry valley" system. My worry is I'm surrounded by trees and this will get clogged and full of junk. I can get something like this GRP open dry valley locally and collected easily or I can opt for something like a Kytun Aluminium valley which will take 2 weeks to come. https://www.travisperkins.co.uk/fibreglass-valleys/danelaw-group-tile-valley-trough-grey-380mm-x-3m-rp3/p/915427 I can't really see the valleys from ground level so this is all about performance. Any thoughts on what I should do?
Hello folks! A quick sanity check. Norrsken want quite a sum of money ( it will be around £1200 inc vat on around 10 windows / doors ) Simply put should I leave it to them or do it myself? I am guessing there is a few hundred pounds worth of tape there. Norssken use 'Elite Installations' to do their installs.
