This is for a new workshop floor. To make it smooth and level, I'm using a flow screed onto the concrete slab (with adhesion promoter/seal on first). However, do I need perimeter edge foam?
The floor is entirely unheated so why would the concrete slab and bonded screed expand at different rates? I've also seen stated that with unheated floors, edge insulation is all about preventing heat transfer between floor and walls, but in this case they'll basically be at the same temperature so that would not be an issue.
Apart from the (not huge) cost of 100m of perimeter edge foam, seems to me that allowing the screed to bond fully to not only the concrete base, but also into the roughness of the concrete block wall has to be a good thing. Preventing such bonding surely results in a weaker structure - as long as thermal expansion is not going to create a problem.
I will need to seal up any gaps to prevent the screed from flowing away where it should not, but is perimeter edge foam required, or would it be better to let the screed fully bond not only to the concrete base but also the block walls?
