price up part online. You can put stuff into clean them but may block up again. If it is your plate then maybe a system flush is needed to so it doesn't happen again. Hope its just your cartridge
massive improvement in comfort. Im putting a breathable membrane down with 140mm and 90mm (max depth possible with pipes etc) frametherm insulation. Still not decided if il put a vapour barrier down though
Hi Iceverge,
I'm been thinking about my floor and think iv changed my mind to rockwool slabs for under the floor.
My joists are 90mm thick. Would it be better to hang the breathable membrane lower than the joists and fit 125mm (or more) or keep it inline with the bottom of the joists and fit 100mm?
Thanks
S
there is also 2 exterior walls i can go with 50mm pir on top which will make a big difference. I will be double checking that when i get home in a few weeks
I'm stripping everything out start of next month. Il see if 90mm will fit ok. Would pushing the 80mm PIR right back and leaving an air gap at the front be better?
New kitchen is really tight so literally ever mm counts. I will get away using 25mm most places but one wall will need 20mm
