VinsJack
VinsJack's Achievements
New Member
New Member (2/5)
1
  1. The second problem seems to be solved... a security function was blocking the reading of any value if the query was coming from a device not sharing the same protocol... once deactivated the security protocol everything started to work... now oly some parameters are missing... PLEASE HEEEEELP!
  2. Dear all, i hope someone could help me with my issue. I have the following system: 1x SE6000H inverter 1x Storedge connection unit 2x LG Resu 10h prime 1x KNX modbus TCP weinzierl Gateway 716 Actually i can potentially acquire all registers from 40001 to 41275 however i know the description of few of them (the one listed on the attached document) Main issue is how to get all info about batteries (i have no idea baout which registers are required The second is about the KNX configuration... actually i can read values only immediately after modbus request, but i'm not able to perform any operation or function on those data... after a query, the value is always unavailable/zero... any idea about it? sunspec-implementation-technical-note (4).pdf
  3. Hi All, sorry if i'm opening again this topic. I have an issue to integrate my Solaredge inverter and 2 LG Resu Prime batteries in my KNX system using a TCP modbus gateway. I'm able to several data from the inverter but i'm not able to acquire any information about batteries SoC, SoH, temperature and status (charging, discharging, idle). Could anyone help me to find the right addresses and check my settings?
  4. Hi All, I'm Vins from Italy... i'm here to try to find solutions to my home automation issue... A neverending story because it's my own house and it's still a work in progress... since more than 10 years... Please forgive me if my english is not perfect... Thanks a lot in advance for your help!
