ashthecat
ashthecat's Achievements
New Member
New Member (2/5)
0
  1. Hi, I’m installing a sedum roof onto a 20 sq m garden room GRP flat roof. A common system seems to be: drainage layer on the bottom, then substrate, then sedum roll on top. But some companies sell a lightweight substrate roll e.g. https://thegreenroofcompany.co.uk/product/sempergreen-lightweight-system/ while others use a loose growing medium e.g. https://www.sedumsupply.co.uk/green-roof/growing-mediums/ instead. Is either one better? And I’m concerned about the weight if using a loose growing medium. My calculations are: Joists - 21.5cm deep x 5cm width 40cm between joists centre to centre span 4m (front to back of garden room) https://www.timberbeamcalculator.co.uk/en-gb/span-table/floor-joists?load=1.5&class=C24 says with up to 1.25 kN/sq m, ie 127 Kg / sq m weight, joists can be 4.414m long Total weight per sq m: Sedum roll 400kg (I bought it, that’s what it weighs!) / 20 sq m = 20 Kg / sq m Growing medium (recommended 1.5 - 2 bags / sq m) say 1.5 of the 25Kg bags: 37.5 Kg / sq m or when wet multiply by 1.5? So 56 Kg / sq m GRP 14 Kg / sq m Plywood 4 Kg / sq m TOTAL: 94 Kg / sq m So it is under the 127 Kg / sq m maximum, so should be OK? Can anyone check this and say if they agree?
