Fred F
Everything posted by Fred F
We had a similar issue with a 50m lane which was also not wide enough (needs to be 3.7m). It was never a planning issue - it only came up with building control. We also tried to speak directly to the fire service but they would only respond to formal consultations through building control. Both of them just said we had to comply with approved document B and didn’t provide any guidance on what might be acceptable. It was quite a frustrating experience with us throwing ideas at them until something worked. In the end I was able to comply with approved document B by widening the lane using grass grids (there is more than 3.7m of total width but only 3m was hard standing) and I used swept path analysis software to show that, whilst there was not space for a full turning circle, there was ample room for a fire engine to do a three point turn by driving from the lane into our driveway, then reversing back out onto the lane, and then driving forwards the way it had come. Our gates need to be wide enough to allow this to happen. Hope that helps. I imagine it is different for all fire services and BCOs as there is flexibility under the building regs to show equivalent compliance without exactly meeting the letter of approved document B and hence there is an element of judgement involved.
Just to close off this topic from me, in the end we agreed to reinforce the grass verge with plastic grass grids which was considered adequate from building control and the fire service.
We had the same issue. I didn’t want to waste time and money on the UU since we already had one for not being able to hit net zero and so have to make a carbon offset contribution. Every time we amend the UU we have to pay the council £540 in costs. It’s such a racket! Instead we paid around £1.5k for an ecologist to calculate the baseline and come up with a plan. Even though we did that I still had a condition to discharge which involved drawing a landscape map showing where the trees would go which was basically a rehash of what the ecologist had already done. I did that myself in PowerPoint. Fortunately it was very easy to discharge that condition.
The house will be about 70m away from the highway unfortunately. Sounds like we'd better speak to the fire service! Thanks
Yep but we need to get it signed off by building control, don’t we?
Thanks for all the responses. 3.7m did indeed come from Approved Document B. See p99 of this document: https://assets.publishing.service.gov.uk/media/639ae7e98fa8f5069839c7d7/Approved_Document_B__fire_safety__volume_1_-_Dwellings__2019_edition_incorporating_2020_and_2022_amendments.pdf There is space to turn using a hammerhead. I think the main constraint is width of the track. I wondered whether people had had any luck convincing the local fire service to accept a track that was less wide than strictly required?
Hi all, My plot is at the end of a straight private access road which is 5m wide but with hardstanding of 3.2m width and the rest grass verge. This is below the 3.7m required but should be straightforward to get a fire engine down. Do you think this would be acceptable for building control? If not, what would my options be? Hydrant would not be ideal. Thanks.
Sorry to take so long to follow up! The planning officer advised me to make a S73 application to have the condition removed. I happened to need to do one anyway due to some tweaks to the design which in my view were pretty minor but had already been knocked back in an NMA. So I did the S73 and after 8 weeks of hearing nothing was told that because my original application did not tick the self build box (an oversight of my original architect) I would need to submit a fresh FULL application because a S73 coils not change the type of development. Obviously I didn’t want to do this so decided to just discharge the BNG condition. Fortunately discharging the condition was surprisingly easy. I just sent a landscaping map showing where I planned to plant the trees and that I would keep some existing trees. This was deemed sufficient. So a bit of a headache but all ended up fine! Now going through building control and hope to get started in the new year!
Thank you all for the kind responses! I'll speak to the planners and see what they say. Fingers crossed it is straightforward.
Thanks Garry. Since the approval has already been issued with this condition, would the right course of action be a S73 application to have the condition removed?
Hi everyone, First post alert! I’ve recently received permission for a self build on a piece of brownfield land. There is a BNG condition and I’m not 100% sure how to discharge it. I thought self-builders were exempt from BNG but my LPA seems to be taking a different view (which I suppose is their prerogative). I would really love to avoid entering into a S106 if possible, especially as the condition mentions perpetuity as the duration, which seems rather unreasonable since the national guidance is for 30 years. My site is mostly hardstanding so the baseline is very low – there are two small trees (which we intend to keep) plus some grass/weeds. The baseline is 0.13 units. Do you think I could argue that presenting my BNG plan should be sufficient to discharge the condition without requiring a S106 or conservation covenant due to: a) being a self-builder who could be exempted under national guidance; plus b) with the baseline being so low, any reasonable domestic garden should easily achieve 10% gain (and in fact my landscaping plan achieves 60% due to the anticipated planting of a few more small trees)? Any guidance is appreciated. I have already entered one S106 with my LPA due to not being able to meet net zero which cost me £800 in their legal fees and a further £500 for them to monitor it. I’d rather avoid additional costs on BNG, especially if monitoring is required into perpetuity (how much would that even cost?!). Thanks, Fred. For reference, here is the exact wording: No development above slab level shall commence until a Biodiversity Net Gain Plan based on the net gain information dated [XXX], that details how the habitats on the site will be created, established, managed, and monitored in perpetuity, has been submitted to and approved in writing by the Local Planning Authority. The Biodiversity Net Gain Plan shall thereafter be implemented.
