Hi, that's interesting, I am just trying to get the heat pump to run as efficiently as possible and looking at the flow rate/heat pump on ,off and wondering if it was excessive
Can anybody tell me why my flow rate oscillates so frequently, the image is over 24 hrs. The Heat pump is controlled by a Homely, but that does not control flow rate.
Hi, I have got a 9kw LG monobloc heat pump, does anybody know the correct setting for the water pump flow control, there are three settings Pump Capacity, Optimal and Delta T, it does have a buffer tank in the system, thanks
Thanks for replying, the homely website tells you how to wire the homely up in the house and where to connect on the heat pump but does not tell you what heat pump/homely uses as a trigger/feed for the post buffer circulating pump and the 3 way valve.
