Matthewr
Personal Information
  • Location
    Bradford on Avon
Matthewr's Achievements
New Member
New Member (2/5)
0
  1. Hi I'm joining this forum rather late in the day but have read through with interest as I have the same challenge as others who've contributed, i.e. a gas powered, ducted warm air heating system that I'd like to convert to using an ASHP. The current system is based on a J&S WarmCair warm air unit. This has a conventional condensing gas boiler that currently heats water to 70degC. The heated water passes through a water to air heat exchanger over which a fan blows air, providing ducted warm air for space heating. The heated water also passes through a heating coil in a hot water cylinder to provide domestic hot water. I appreciate that the system installed by @severnside uses an air-to-air heat pump but, as I live not far from Bristol, I wondered, would you be able to share the name of the installer you used so that I could explore whether they could work to convert my system as well?
  2. Hi. I'm interested in replacing gas powered warm air heating with ASHP.
