Thanks for your reply and thoughts on flooring - LVT was just an alternative to the tiles in the hallway, but nothing finalised.
We plan on upgrading roof insulation, changing all windows to double glazing (we've just got the keys, so work is necessary), and appropriate underfloor insulation. Then I'll look into internal insulation on front and back walls (Externally facing).
I did heat calcs based on the assumed changes (ex wall insulation for now), and reached heat loss of 7,000W, meaning I'd need a heat output of around 80 W/M2 in greater london. With that said I'd like to get a specialist in to do their own calcs.
Thanks - it seems like the best option.
Thanks very much for sharing thoughts.
1. Not planning on digging out concrete, will try to bridge the gap between joist and concrete with either omnie torfloor boards or the self leveller on top of plastic panels.
2. I've been reading about the non-breathability of PIR, but many seem to claim that on a suspended ventilated floor it works. I'm happy to use a different type of insulation as long as there is efficient reflective ability for the UFH. Thanks for sharing that article, need to evaluate u-value differentials, but I do prefer maintaining breathability (potentially hindering some of the heat retention).
3. Ideally I'd get it done, so I'll just have to check. At the same time, hard for me to see the benefits of heating under there unless we change the kitchen layout.
4. Plenty of room as ceilings are quite high. As you mention stairs and doors being the main limitation, we'd be ok with losing up to 30/40mm all in.
Thanks! I do hope these dreams do come true - would be great to get the character of these old houses coupled with some decent UFH, slightly better efficiency, and no rot!
