MRH1234
MRH1234's Achievements
New Member
New Member (2/5)
0
  1. Hi, yes I did look at the manual, but to be honest it wasnt clear to me what they were doing. I have a buffer tank, so the next question is how would I balance either side of the buffer? I have 2 manifolds and they both have the send to them and return all be it 10-15m apart. They are not casacaded ie ones return feeding the other which I believe can be the case. My theory was the primary bypass wouldnt be needed as if the ASHP has a demand then there would be flow and if not then the pump would be off anyway and bypassing back a percentage of your hot water back to the tank will only lose heat on its trip round and this would be better just going round the manifold loops that was calling for heat. I have to assume the installers didnt touch either primary or secondary.
  2. I possibly have a problem with my Ivar unimix mixer and just wanted to understand the primary and secondary bypasses better. Does the primary bypass have no use with an ASHP setup and can be set to minimum/closed? And what is the use of the secondary bypass, is it setting the amount of flow from the return that can go back in to the send flow? And therefore its for setting a range the actuator can work over?
