Havkey100
Havkey100's Achievements
Member
Member (3/5)
29
  1. That's what we have done. Noggins around the Finn Joists. Currently the 22mm T&G is in place, ready to be cut through when the duct is installed. Ours are 108mm insulated pipes.
  2. Yes, it is not a terrible situation, but bleeding fees on selling/purchasing is a bit frustrating
  3. I must admit we are running into something similar with Ecology. We were given a land valuation that honestly was much lower than is reasonable for the area. We are putting a large 4 bed on a 700m2 plot and Ecology valued it at £115k. Initially I didn't really care as I wanted to get going with the build. In practice, if I tried to purchase a similar plot in the area I would be looking at £200k+. Our first draw down was £90k based on the land value. With the benefit of hindsight I would have questioned this more, as it really would have given us more breathing room. The overall build valuation also seems light for the area, as for the same size house on a similar plots I see asking prices about 30% above our valuation. We completed the ground works and slab and have just had the valuation for the the second draw down. The first draw down barely covered the cost of the slab, ground works and prelims. We expect that the valuation may barely release what we need to complete the superstructure, when our next major bill drops. After that, it seems we need to time the completion of the watertight shell perfectly so that we can get the valuer back out. Honestly, it all seems backwards. We have the funding in place to cover everything we need, our builder works in arears, with payment typically due 1 week after the end of the month. However, the build is fast, and I feel like the lending structure leaves a potential bridging gap. It is not big, but runs a few weeks behind what I would really prefer. I haven't really worked through the solution. We have access to the funds if needed, but I didn't expect to have to sell shares to cover these timing gaps.
  4. Very appreciative of this thread as I have been hugely paranoid in this area. We have our exemption and have submitted our commencement notice, however are due a decision on a minor amendment next week to firm up some window positions. Due to the timing, I think we may therefore need to resubmit/update our commencement notice once we have a decision. This whole area is a minefield for legitimate self builders it seems.
  5. Yes, have been speaking with the heating engineer. Looking at the options on HPs at present. @JohnMo thanks for the input. Direction is low power HP, reasonable cylinder size of 300l or so, wet U/F and as per @Iceverge electric u/f in bathrooms and electric towel rails. On the MHVR I am investigating options as I am very tempted to DIY as I believe I can probably do the lot for 4-5k in a week myself with a spare pair of hands from my wife.
  6. Yes, you're right on the overheating. I am inclined to not commit to anything on that front as I would rather run the system for a year and see how we manage. If we find we have an issue then we would maybe consider split air in one of the main rooms. 1% over 25 degrees, I believe peak was 26 degrees. Not sure on the solar gain impact of the PV, I assume it is embedded in the PHPP methodology as the calculation takes input on the array size. Location is Bristol, non coastal.
  7. Thanks, that's why I posted. Agree on HP controls. Have one at the minute and it's unzoned. If I can get that install at less than £5k I'm happy. MHVR seems like it's 4k components, 2k ducting, 4k install, but am working on prices around that. Seems a big racket on it by installers at present.
  8. All, PHPP calcs are in and we are firmly in between Passivhaus Plus and Passivhaus Premium by design, less than 0.6ACH, with overheating risk at 1%. Amazing of course, but the one slight downside of all of this is the multitude of options for heating and ventilation. The solar installation will be 9-13kw of solar (pending DNO approval), a 15kw battery, with no gas installed on site. May consider a V2X Sigenstor as my car has that feature and I have access to free charging. The basic issue is that we can almost heat the house with a toaster, therefore a heat pump system is for the most part going to provide HW in an unvented cylinder for a family of 5, with only periodic use via a wet U/F loop downstairs on the insulated raft. The MHVR solution is likely to be a Zehnder Q450. I am trying to weigh up all the permutations we can try in order to minimise capital cost and simplify controls. So far my considerations are: 1. MHVR Heating/Partial Cooling with Direct Hot Water Cylinder - £16k Zehnder Q450 and Comfoclime add on HP, which gives about 2kw of heating and cooling capacity. It comes in at £13k and has the benefit that it likely has all the heating capacity we would ever need, can temper hot conditions (clearly not a full blown AC, but 2kw of cooling would help a lot). OSO 300L DHW cylinder. Can heat overnight on an agile tariff, economy 7, and recharge daytime from battery, V2X if needed. £2k installed. Contingency install U/F loop in case the above is less liveable than we hope. £1k 2. MHVR with 5KW HP HP Cylinder - £18k Zehnder Q450 £10k Vaillant Arotherm 5KW with 300l Vaillant HP Cylinder. £7k out of pocket. U/F loop in case the above is less liveable than we hope. £1k 3. MHVR with Direct Hot Water Cylinder and IR/Electric Heating - £14.5k Zehnder Q450 £10k OSO 300L DHW cylinder. £2k installed Strategic Electric Heating - IR or a few towel rails in the extract locations of the MHVR loop - £1.5k. Contingency install U/F loop in case the above is less liveable than we hope. £1k Any other options I am missing here? I am inclined to go with option 1 as it is a bit cheaper, harmonises the controls, and in practice I can't imagine it will cost any more or less in practice to run, plus has some cooling capability. I was also considering the NIBE S735C, but am struggling to lock in pricing on that. I think it may come in at 20k and is an entirely integrated solution from which I could heat via air, u/f, ventilate, cool and manage HW with 300l of storage. But, the issue is the overlap of heating and cooling adds complexity to ownership of an installation between the MHVR designer and heating engineer. Thanks for any input and experience!
  9. I wish I had pushed a bit. Our original request from our case officer: Apologies for the delay in responding. I can confirm I have now written the report for this proposal with a recommendation for approval. Please find attached the conditions for your agreement. Due to the number of comments that are contrary to the officer recommendation the application must be published on the Council’s Circulated Schedule before a decision can be issued. The next CS will run from the 25th April – 2nd May. Whilst the application is on the CS Members can choose to call the application to Committee. If the application is not called in, it will be issued as a delegated approval by the 6th May. If the application is called to Committee I will be in touch with the relevant dates. It would be appreciated if you were able to agree to an extension of time to the 6th May to accommodate the Circulated Schedule process. They then changed their decision in the extension window forcing us to appeal (which we won after a 7 month delay!) I always wondered what may have happened if we had been obtuse. Probably our case officer's line manager would have been still on leave and we would have avoided the lost time...
  10. Yeah, only my 11 year old was around at the time. Had to use him for emotional support lol.
  11. Submitted mid August Started 25th September Site Visit 18th December Decision this week.
  12. Appeal Decision notice attached for anyone who is interested. 3350167 Appeal Decision (1).pdf
  13. In my opinion having a clear island is much better. When hosting, you have two separate congregation points, without cooker mess and paraphernalia in the way. Cooking than then be kept separate. I used to think otherwise, but having just been to a friends new home, they have the cooker against the wall, a similar sized island to your proposal, and it worked really well as a gathering space.
  14. Relevant sections: 12. One of the closing paragraphs of the TAN deals with the planning balance in the determination of planning applications. In this case I have found that in terms of the main issue that most of No 37’s external areas would not lack acceptable outlook or be dominated or suffer adverse visual impact if the proposed new house were built. The same would apply to the large room served by the French doors. I find differently in respect of the bedroom. However, having regard to the many factors in the development’s favour, this is insufficient reason, in itself, to refuse permission. 13. In conclusion, I find, on balance, the proposed development would not unacceptably harm the living conditions of No 37’s future residents. Accordingly, I find that no significant conflict arises with those provisions of Policy PSP8 of the South Gloucestershire Local Plan Policies, Sites and Places Plan directed to ensure that new development should not have an unacceptable impact on the residential amenity of occupiers of nearby property. At some point I will drop in my appeal document. It is hefty, but I tried to leave no stone unturned.
  15. Massively. It has added a 7 month delay. We are lucky in that we are at my in laws, the house is spacious so we have no real issues.
