GaryBixhall1984
GaryBixhall1984's Achievements
Member
Member (3/5)
1
  1. Ok I can possibly be near Southampton/Portsmouth area over next couple of weeks if that helps!
  2. @Sparrowhawkwhere are you based?
  3. 1,100 sq ft - but Airflow make much bigger units too. Parts super reasonable online.
  4. Hey all - I have the below kit left over from my install - I am in London so let me know if you want anything: - approx 35metres 75mm semi-rigid ducting - 2 x 1.8m lengths of 125mm white rigid ducting - 2 x t-piece 125mm rigid pipe connector - 2 x 90 degree elbow 125mm rigid white connectors - 4 x 125mm jubilee clips - 1 x momentary wall switch for boost mode - some foil backed insulation for wrapping pipes Any ideas what I can do with all this stuff?? Cheers
  5. My Adroit DV96 from Airflow is actually a Finnish built unit, and I cannot say I have masses of experience but I had a Nuaire previously and found it pretty basic / parts super expensive, hence I replaced it. I control the unit from my phone using their cloud services, its super comprehensive, with detailed data. I really love it!
  6. Thanks for that - still not super clear but I'm happy with all the numbers I am getting and its perfectly balanced so I guess I am good to go!
  7. Ah got you! I'll keep an eye out for more!
  8. I bought these from VentillationLand - the ErgoVent and I love them. Do you have a link to the eBay for 2 for £70?!?! Thanks!
  9. Hi all, first off thanks for being a great resource. I have just finished installing an Adroit D96 and it's working great. I used the forum more than a few times to work everything out, thanks! I am now commissioning and have the designed rates from a company. I am assuming these are the rates when the system is in boost mode, is that how these commissioning figures are supplied normally? Also in Part F I see 0.3l/s is required per m2. So my house is 110m2, so need around 34 l/s extract and same for supply. Is this the constant ventilation or on boost, I think it's constant? It just seems very high. I know people on here dial settings down from Part F but just want it right at commissioning time. To get the designed values and satisfy Part F my system is running at 60% extract and same supply. Does that sound high? Thanks and appreciate the help in advance! Gavin
