Walrus
Everything posted by Walrus
  1. They're bolted together so moving them would just mean undoing the bolts (main reason being so that they can't be prised apart for access). It would be a few hours of faffing, but they could be moved seperately. I did it this way with the thought in mind that if I can ever put them on my own land I could still move them.
  2. Could I put a 'kiosk' next to the pole, on the concrete pad and have the connections run into that? This is what it looks like inside the existing box on the pole:
  3. I didn't know a landlord-meter was a thing! She would be quite happy with this, as would I - the point is I want a connection I can run a welder from that won't interfere with the existing connections. 16A would be enough, so 40A overall would be plenty. Can you suggest where I look into this further?
  4. Don't know if cross-posting to other forums is allowed(!), but I have documented my build here: https://www.garagejournal.com/forum/threads/shipping-container-workshop-aka-the-bunker.480285/#post-9067112
  5. I've built myself a workshop using a shipping container. A 40' high-cube on a concrete pad, cut in half, ends welding up, sitting side by side. I cut out the wall between to make a bigger space, lined & insulated it, added some vents, installed basic lights & power, and internet (as it's a big faraday cage inside with the doors closed). The whole thing is classed as a 'temporary' structure (mine is the green unit on the left). The reason I'm here is to get electrical advice; I'm currently running lights, tools etc from the unit next door on a single extension lead! I want to get my own standalone power connection as I want to run a welder (for car repairs) - this is for hobby (domestic) use, not as a business - and as cheaply as possible while staying on the right side of the regulations/law. There is a power pole next to the unit that the existing units run from and site owner is happy for me to get my own standalone connection & meter. I have no idea how I arrange/organise this. I got a quote from an electrician for £3k to supply and fit a connection, fuse board, 2 sockets, 2 lights (no meter) from the existing power pole - this seems a bit steep! I was wondering if I can get a connection to a 'kiosk' behind my unit with a 16A plug for a welder and a couple of sockets to run lights & tools from? Can I use the existing connection from the power pole or do I need a new one? How do I go about getting a meter installed?
