GK22
Everything posted by GK22
New build designs........ Comments please
GK22 replied to GK22's topic in New House & Self Build Design
I am not a self builder by any stretch of imagination. I only commissioned a self build and project manged everything. So BH was my go to for any references and knowledge. The wide range of topics and discussions are quite useful to get a basic understanding of the build process. I found that quite useful to have the background knowledge to deal with the different trades I had used. In terms of the Build itself, it took approximately 12 months from spade in ground to moving in. Considering the size and complexity of the project, I am quite pleased with the time scales. In terms of lessons learnt: 1 Time and money will always be more than you plan. CONTINGENCY is key. 2. Always have a Plan B and C 3. Adaptability and flexibility as when problems arise. Dont be too rigid. 4. There is no or very little point in getting angry or upset with your trades and workers. 5. Maintain a healthy working relationship and make your point in a firm and calm manner. 6. Find someone -either family or friends or even strangers in forums like this to have a chat or outlet. I think this aspect is really critical to stay sane during the build process. 7. Plan for paperwork and certification right from the beginning. This is something I wish I had planned from the outset to avoid unnecessary delays in getting the sign off. 8. As someone with very little experience, I had to use an architect for consulting through out the build process. I found this really helpful. 9. The whole process is really stressful, especially during the bad days. So its important to think of the end product but also look backward to see how far you have progressed in the journey! 10. Remember to keep smiling and enjoy the journey. -
Hi All Its been a while since I updated this forum. I just would like to say a big Thank you to all the BH community. The build is now complete and we moved in Sep 24. Many Thanks for all the valuable comments and also the extensive info on various topics. Quite helpful. BW G -
Are these costs realistic for a 500m2 house
GK22 replied to miike's topic in General Self Build & DIY Discussion
I am looking at approx 2400-2500 per m2 to finish... that's if no more surprises! 200k to finish a build your size would be phenomenal. -
Hi Miike That's interesting. Can you post some pictures. Thanks -
Hi All I have been looking at ASHP and DHW for my self build. I have attached a quote from a specialist supplier. This is supply only. I am going for a MBC passive standard and hope to achieve excellent air tightness and u values. MBC will also lay the UFH pipes for GF. I was not planning on any UFH for FF. The quote insists on UFH for both GF and FF. To be eligible for the BUS grant. My questions are 1. Is this quote reasonable? 2. Have they got the ASHP capacity right? 3. Is RIELLO a good brand 4. How do I get around the issue of the UFH ? As always very thankful for all the help and support. BW G ASHP BH.pdf
MVHR for 335 m2 house
GK22 replied to GK22's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Just received this quote for MVHR install. House 335m2, really air tight and well insulated. Please comment. -
Services 1x Zehnder CAQ600 MVHR unit with integrated defrost heater 3,727.93 Services 1x Zehnder LAN C Controller for app smart phone/tablet control 232.16 Services All duct work materials: EPP insulated ducting for intake andexhaust ducts to external metal combi grill. 200mm metal ducting with safe seals to manifolds. 90mm PE antimicrobial and antistatic Semi rigid ducting to plenums. Designer metal Airy air valves throughout. Kitchen valve with integrated grease filter 3,997.99 Services MVHR Design fee 745.00 Services Install ductwork (First fix works) 2,950.00 Services Install MVHR unit (Second fix works) 850.00 Services Commission MVHR system & produce a report for building control 850.00 Please see terms and conditions attached, and note services not carried out by us (eg plumbing, electrics etc), which you will need to ensure are carried out. SUBTOTAL 13,353.08 VAT TOTAL 0.00 TOTAL £13,353.08 TOTAL £13,353.08
Hi All Received this quote to dig a trench for all the utilities to service the plot from the main road/supply points. Is this reasonable. Thanks Quotation for works To excavate service trench from the road boundary hedge, across the field and into site (approx. 160m) Supply and install 1 x 32mm barrier water pipe and all fittings To install 1 x 96.5mm BT ducting (supplied by BT) To supply and install 1 x 150mm gas ducting Electric cable will be installed into excavated trench by WPD All to be bedded on and backfilled with sand with appropriate marker tapes Trench to be compacted and reinstated back to agricultural field Total cost – £16126.00 + VAT Please be aware- If you wish to install another barrier pipe at the same time the cost would be £1950+ VAT. This quotation includes all labour, machinery and materials for the above works only. Any other works can be undertaken at an agreed hourly rate. I estimate these repairs will take between 8-12 days.
Hi Kelvin Does this include the soffits, fascia as well. What soffits finish are you going for Thanks
maybe I wasn't clear earlier. i have used a QS to get an estimate of the build costs already and in the process of getting quotes for the roof once the design detail is finalised. Specifically i was asking how you arrived at that figure of extra £250 k just for the mono pitch roof design as compared to a standard roof. So its your gut 😀 -
MBC high performance TF with double glazing Reynars windows and doors -
I knew it'll add extra cost but didn't realise it would be this much. Can you let me know if there is an objective way to calculate the costs. I am working on 2000-2400/m2 as over all build costs. Thinking of MBC high performance timber frame as the first option. -
Yes. At the moment discussing ideas. Roof detail not finalised yet -
which one are you referring to ? -
Agree with your comments. Did do a version without split roofs. See below... Absolutely with you on the detail of the final roof finish/soffits/edges etc. I am spending time on research and fine details. So any experts on metal roof finish please comment -
I am thinking of ASHP and MVHR... so NO smoke pipes 😀 -
Surprisingly mine DID 😀 -
Thanks Kelvin -
Hi The 3D modelling was done early on and some of the design details are not incorporated. But the elevations in the pdf doc show the gutters and pipes. Yes the roof is either Zinc or Greencoat based on the costs -
Thanks. Agree and I replied to an earlier comment... render is still not finalised -
Thanks pats. have look at the attached too.. Let me know if you can't access it -
Hi Dave Still haven't finalised the final external finish. I am thinking of k rend/stone and timber cladding. But not sure which bits go where. Still debating -
Thanks. Glad this will at least be a nice car show room 😀 -
Thank you. Agree with the points on north elevation with a lot of render. Will break it with some cladding ideas and/or trellis. room-by-room PHPP analysis - So far have got quotes for overheating calculations using Dynamic Thermal remodelling and SAP 10 Calculations & Predicated PEA's/EPC's (Approved Document Part L) - A bit out of depth here and need to do some research. Any help and advice would be gratefully received.
