andy1300gt
Everything posted by andy1300gt
  1. Straight from the boiler at moment. Its hard to judge at the moment as the sun is shining. We all know we get day on end with little to no PV. I just want wring every last Kwh I can out of it.
  2. 2 x photovoltaic. 1 Solaredge and 1 Sunsynk with battery storage. I have bought the MyEnergi Eddi , yet to be fitted, to help control the PV. I would hope to use the buffer to pre-heat both UFH and store for hot water. My logic tells me one thing but my ability to get my head around it says another......
  3. I'm in the process of putting together something, but I just keep going round in circles. I have two separate solar set ups. UFH and trying to connect a Willis immersion heater. Which does work (manually at the moment) LPG combi boiler for heating and hot water. I do have a log burner, but logs are getting expensive now and it would be nice to be a little greener. So, buffer tank to pre-heat the water to the boiler? Its all the routing with the suitable relays and switches I can't get my head round.
  4. Not at all. Just seems like everyone is in Scotland or Wales :-)
  5. Good Afternoon! I'm looking for any clever folk in the Mid Cornwall area that would be up for meeting up. I need to find someone who has a passion for designing multi service heating and hot water systems. Open to experimental idea's. Cheers
  6. It can work out quite expensive and time consuming if you need to take it to the local tip. What does it cost? Material Description Charges from 1 August 2019 Asbestos Bonded type only A small domestic roofing sheet is approximately 180cm x 90cm. You will be charged for any item the site staff believes contains asbestos. All asbestos must be double wrapped/bagged in strong plastic. £10.80 Per sheet or bag It may be different where you are though. This one was 5 x 10m.
  7. I removed a Nissen style concrete asbestos garage a few years ago. As suggested if contact someone like Biffa and they can supply a sealed container. I hired a Genie type lift to lower the pieces down. Keep it well watered, now cutting with a saw.
