gambo
gambo's Achievements
Member (3/5)
1
I bought centrifugal fan known and sold in the UK as monsoon UEC100 but it's the same as VCN100. It has 190mm centrifugal AC fan from Blauberg. Installed outside and connected to 1.5m galv ducting with 1 90degree bend. It's not finished yet and at full speed the noise in the kitchen is ok but the it's too noisy outside. Having done some research about reducing the speed I realised it would be better to have EC fan so that I don't have buzzing speed controller in the kitchen. Tbh I don't want speed controller at all as the walls are finished so I may just use resistors to slow the fan permanently to acceptable level. Anyway, given I want to swap the motor with a EC fan Im thinking whether to buy something with better parameters but blauberg offers number of different fans with different parameters. Is there a specific one that would optimize the performance and noise? https://www.creoven.co.uk/centrifugal-fans/vcn/a-1353205204
Are kitchen extractor designs all rubbish?
gambo replied to SimonD's topic in Kitchen & Household Appliances
Is this just a regular dimmer or 1-1.5a speed controller? I bought a light dimmer but atter some reading I don't think it's the right thing. -
I was lucky to prepare it during renovation so there is a duct with only one 90degree bend. The total run to outside is less than 1.5m. the bad stuff is that we could only easily fit 100mm pipe due to limited space and the wiring is hanging from the ceiling in the kitchen so I would need to either keep the wire inside the pipe to the fan or find a way to run it outside the pipe but without ripping too much of the ceiling. Any recommendations for grease filter solutions? I want to add one as it will also add a bit of sound and heat insulation between the outside air and kitchen. -
At what speed do you normally run it? It's quite noisy at max speed so a bit worried about neighbours. What was your solution for the hood? Custom or just ripped apart a kitchen extractor fan with hood? -
Do you remember how dimmer switch was connected? Ive just got my fan delivered and there is very little in the manual. I think there are two ways of connecting dimmer, one is adding dimmer separately (2 additional connectors inside the fan and probably work with capacitor) or just replace fan switch with a dimmer. -
It's late 80s house build, I think, by David wilson. This has ducting is not the worse I've seen during the renovation. The other end is probably around the water meter 12m from this place and around 4m from the fron of the house, although I can't see it due to an amount of mess/soil around the meter. I spent 1hr digging and removing the soil just to be able to turn off water. If the condensation is from either some sort of leak (would need to be very small if the meter doesn't move when turned off) or rain/soil then isn't it better to let it escape by not pushing the pipe insulation to deep? If I put pipe insulation that doesn't go inside the hole than that covered pipe doesn't attract condensation and it just sits and breath on the pipe inside the hole.
Yes, unfortunately there is no leak at stopcock. I've checked it in number of ways. I can feel and smell damp further down and it smells like when you are inside bristol-bath two tunnels path.
I've now removed rockwool mineral wool from the hole and the pipe insulation from mdpe. The mineral wool is wet at the bottom. Not very wet but enough to assume that it may get quite wet if left for longer. I know it's breathable but will this not cause an issue if it attracts condensation quicker than it breaths? I wonder if just leaving it open is more sensible. I can cover the pipe partially as the whole and angle of the pipe doesn't allow to push it all the way to the ducting.
But mineral wool will slow down the process of transferring moisture from one side to another, correct? Will this not cause an issue long term (build up of moisture at the bottom side)? My other thread was going to be about usage of the foil below mineral wool in the loft but I guess I would need a very well specified mvhr to avoid build up of moisture beneath the foil.
@andyscotland wow! That's a great explanation!! Thank you! I'll keep it wrapped (did it a few days ago) a bit longer and will unwrap it just before covering with units to see where and how much if condensation is there, and will give an update.
It's not difficul to graspz but i see gaps in what some suggest. I don't see how filling the hole with mineral wool can be any better than covering it with foil+ PIR. Im trying to understand the whole process of forming the condensation to make sure Im bit causing bigger issue later on.
Iim more than happy to give you my postcode but it's a rabbit hole with lots of other issues waiting for a separate threads. Anyway, I do have pipe insulation just don't understand what I'm gaining by installing it. If I read your answer correctly, each side of the tile has its own reason for moisture so I can't cover it up but by covering the pipe with insulation I'm moving it further up to the next cold spot (stopcock)?
But if it's from the house then it should not penetrate the foil easily or at least I should have moisture on top of the foil too, but the foil is dry.
duct and pipe is buried in the ground/concrete. It has some very low temperature comparing to temp of the house. The duct ends in the hole and the pipe goes out of the hole. I have no idea where the humid air comes from but assuming it comes from somewhere deeper I don't understand why insulating the final run of the pipe would improve it.
I don't mind OTT just but i like if i can remove something easily. Putting foil first and gluing the PIR with expending foam is a good idea. Are you saying that because the hole now has a higher temperature by being warmed up it pulls the air/moisture up? But once i isolate it to keep it at lower temp it will be fine?
